Question about Bosch BSA2222UC Compact Plus Bagged Canister Vacuum
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
OK, I plug in my vacuum, turn the dial half way between ECO and MAX and if i'm lucky, i get 5-6 minutes of suction before the machine totally quits. I wait 5 minutes, 10 minutes, 15 minutes before I hit the dial again and then sometime between 15 and 20 minutes I'm good to go again for another 5-6 minutes....
  • flbucks Jan 03, 2009
    My husband and i looked and looked and could not find any hole near the hose inlet at all. Thanks all the same for trying to help. I DID another test this afternoon and pulled the retractable cord all the way out, set the dial for medium **** (bosch calls it ECO) and I actually was able to run the vacuum for 20 minutes and for the first time shut it off myself... Tomorrow I will try to raise the suction incrementally and see where it lands me...
    New Friend:
I took apart the vacuum, removed the circuit board and cleaned the tiny bits of dust off it carefully, removed the cord winder (without letting it unwind) and carefully replaced both parts, blew dust out of the 2 armature brushes (lifted out the motor, removed the insulation wrap from around it and the 2 rubber gaskets first), then re-wrapped the insulation, replaced the motor, put it all back together making sure the switch was aligned properly, and ran it without the filters, hose, etc, until I was convinced it would stay on without impedance, then added one filter, then another, then the bag, then the hose and lastly the floor head. It never shut off so I think that small amount of dust on the circuit board was the problem. Hope this helps.
Posted on Feb 14, 2013
Pull out the HEPA filter (or the charcoal filter) and you will see an intake port to the side of the main, circular fan intake (it will look like two small slits). Make sure that is unobstructed. If cleaning that doesn't help, remove the screws holding the plastic motor cover in place and remove this cover, pull the small circuit board that holds the on/off switch (very easily done), find the small copper sensing plate with a resistor attached to it and clean that off with some CRC Electronics cleaner. This small copper plate will sit just inside the aforementioned intake port when you reinsert the board. This fixed my shut off problem. Before you throw the whole vacuum away, run it without the HEPA filter if nothing else.
Posted on May 17, 2010
    President:
  • 2,976 Answers
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Posted on Jan 03, 2009
  • David Shaub Jan 03, 2009
    If pulling the cord out made a difference, the problem is in the cord itself, not the automatic shutoff system. You either need a new cord or the contacts in the cordwinder are damaged.
Rainbow E series vacuum shuts downs
When a bearing or the motor brushes go out it will cause the motor to shut down like this. If this is the case and you continue to try to force it there will be potential damage to the armature.
Jul 26, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
Kenmore 26082 Canister Vacuum Shuts off constantly. When Im vaccuuming maybe about 5 minutes later it shuts off. Then give it a few minutes later it turns back on. Whats the problem with this vaccuum
You could have a clog in the hose. Also check your filters, if you haven't changed them in a while, that could be what's suffocating your motor
Aug 19, 2009 | Vacuums
Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Oct 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Vacuum will not power on...
your repairman missed the thermal fuse in the motor compartment
Aug 10, 2008 | Bosch BSA2200UC Bagged Canister Vacuum
Electrolux 2000 Mod# c151c
Turn the knob on top all the way to the right
Jul 04, 2008 | Electrolux UltraLux 2000 Bagged Canister...
While vacuuming the beater stopped.
ok what u have 2 do is replace the belt. real easy so i will tell u how,first unplug the vacuum cause you need your hands for the next step. now turn it over and the part where the roller sits your going to have some screws prolly 2 take them out the cover should come off youll see the roller the pulley and the broken belt if your lucky find the belt size replace it put back together and you should be back in business....
HOPE THIS HELPS GOOD LUCK
Nov 26, 2007 | Bosch BSG81360UC Premium Health Guard...
Bosch BSA2222UC Compact Plus Bagged Canister Vacuum Logo
467 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
