Question about Craftsman Garden
Toe-in gt5000 craftsman garden tractor
Toe-in
3 Suggested Answers
ImpalerCo
  • 13 Answers
SOURCE: replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Posted on Mar 13, 2009
woodchuck789
  • 4070 Answers
SOURCE: Craftsman professional 917.28970 garden tractor
There isn't anything that can be adjusted on your tractor to compensate for the condition. This is something that there have been complaints about since production hit the market with this design. There is a degree of toe-in or toe-out that is normal and by design. Most people (myself included) see anything other than true straight as being an issue.
Because of the complaints and because a lot of machine had so much toe that it was a problem, adjustable drag links are now being produced to alleviate this condition.
  • Left side 71-917-409599
  • Right side 71-917-409600
You will need to get both parts in order to right the situation. If the machine was purchased 2 years ago or less, warranty should cover the replacement. If it is outside of 2 years the warranty will not cover the parts.
If you need to order them, you can go HERE to place the order and have them shipped to your home.
Posted on Jan 13, 2011
What is used to lubricate the transaxle of craftsman gt5000 garden tractor. Is it grease only or 80-90w oil?
If tractor is _very_ old (and/or worn), you can't go wrong with 90-145w gear oil. Someone may have used grease for a bad leak, but heavy gear oil should work for you. Remove as much grease as possible without using solvent, and then fill with heavy gear oil. You'll be ok. (Later on check level and ''top-off'' if necessary).
Aug 16, 2015 | Craftsman Garden
I have a craftsman gt5000 garden tractor 24hp els motor that threw a rod, the end cap broke loose.will the briggs and statton 27hp model 44Q777-3136-g5 work as new motor,the cranksaft dia. and length are...
There should be no reason why not, Just keep in mind of the bolt pattern and measurements as well as you may have to make a few altercations for cables but if shafts match you should be good to go! I hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Sep 25, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
Where is the fuel filter located on a craftsman gt5000?I want to change it, but don't want to screw it up.... I do not have a manual for this rider.
If the fuel filter is not clogged and stopping fuel from going to the carburetor then leave it installed until it is full of particulates and restricting fuel flow.
Jun 08, 2010 | Craftsman GT 5000 26 HP54" Garden Tractor...
I have a craftman GT5000 Lawnmower it quit charging were do i look for alternater?
The charging system is under the flywheel, but first check the 2 wires are connected at the side of the motor, they might be black and white at the conector.
May 01, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
The blades on my craftsman 22hpohv gt5000 won't
Hi, when was the last time you had the carburator serviced, secondly, you must check the governor to make sure it is working correctly under load.
Jun 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
74 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
