Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
KitchenAid 600 mixer stopped running while mixing bread. Slight smell (oily?) from the mixer.
  • 2 more comments
  • Kneadaman Jan 11, 2009
    Brand New just out of the box.  When Kneading dough the mixer heats up and stops running.  It also doesn't sound quite right.
  • kevinm831 Mar 01, 2009
    We were mixing bread and the same thing hapened today.  Wife says she head '2-little cracks' and it stopped.  About 5-6 minutes kneading some pizza dough on the stir settting.  Also, the engine smeeled like burnnt electrical/oil.  I came in about 10-minutes later and was able to turn it on for a 2-3 seconds but it didn't sound good.  Pro 600 - 3.5 years old of moderate use (2-3 times per month).
    We were mixing bread and the same thing hapened today.  Wife says she head '2-little cracks' and it stopped.  About 5-6 minutes kneading some pizza dough on the stir settting.  Also, the engine smelled like burnt electrical/oil.  I came in about 10-minutes later and was able to turn it on for a 2-3 seconds but it didn't sound good.  Pro 600 - 3.5 years old of moderate use (2-3 times per month).
  • Rick Belanger
    Rick Belanger May 11, 2010
    Did you hear a loud CRACK when it stopped? ricardok45
ricardok45
  • 135 Answers
SOURCE: Stopped Mixing While Kneading Bread
Hi again Libby. You're right to be scared about further damage. If you want to fix this machine yourself, stop using the mixer. Go to the Kitchenaid website and download the drawings that match your mixer model Unplug the mixer! Take a screwdriver and remove the silver band from around the head of the unit ( 1 screw). Next remove the four screws that hold the top part of the mixer. Remove that cover, and look for a 'humpy" looking cover at the front of the machine. Examine this transmission cover carefully. If the cover is made of plastic, look for cracks. If you don't find cracks, you'be better off taking it to a repair shop. If you do find cracks in the plastic cover, remove the four screws that secure it. Remove the trans. cover.
You will now see a lot of grease in this exposed transmission. Put on some latex gloves, get a bunch of paper towels and move some of this grease aside so you can lift the worm gear assembly free of the mixer ( see Kitchenaid drawing). Wipe it off and look for damage to the worm (spiral) gear. Look for damage on the other gear of this assembly, inspect the 2 bronze bearings at either end of the shaft. You're looking for cracks in, or pieces missing from the bearings, look for damaged teeth on the gear. Should you find damage at any stage, that part must be replaced. These parts can be ordered from the Kitchenaid website, and will take about a month for them to arrive.
When you order the required parts, insist that the replacement trans. cover be made of metal. When my mixer "blew up", my replacement was a metal one. If your problem dosen't fit the above solution. I can't help you further. If it does, please rate my solution.
Depending how much grease you had to take out to do the inspection, you might have to order a container of grease to replace it. Good luck! ricardok45.
Posted on Jan 31, 2009
bigg t
  • 640 Answers
SOURCE: Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Posted on Mar 07, 2009
ricardok45
  • 135 Answers
SOURCE: LOOKING FOR RECIPE FOR MAKING BREAD DOUGH IN MY
Hi Manfredi. Follow this link to download your mixer's manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Instructions%20and%20Recipes%20-%209704323.pdf
If this solution has assisted you, please rate it. Good luck, and don't overload the mixer when you're making bread dough. ricardok45
Posted on Mar 20, 2009
  • 145 Answers
SOURCE: Kitchenaid Mixer will not lock
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
Posted on Jul 08, 2009
  • 145 Answers
SOURCE: KitchenAid 600, Stand Mixer -
If the beater is grinding when it meets resistance, it generally indicates that an internal gear has broken or been stripped.
With the Professional 600 stand mixer, up to 14 cups of white flour or only 8 cups of any flour are recommended at one time. Speed 2 is the only speed that should be used for bread dough and it should never be kneaded for longer than 7 minutes. Failure to do any of these things make cause problems for the mixer motor.
If you are interested in self-repair, I recommend mendingshed.com. They have internal parts available to order and also have a .pdf file for the Kitchenaid Mixer Service Manual.
If you are interested in a repair facility, please visit the following link:
http://caservice.kitchenaid.com/
This is a listing of certified repair locations.
Also, if the mixer is less than a year old, Kitchenaid may replace it under their 1 Year Manufacturer's Warranty. I would recommend calling their customer service. Their toll-free telephone number is:
1.800.541.6390
Posted on Jul 16, 2009
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
KA 600 is making a clinking noise when mixing.
Tll,
It sounds like it could be an issue with the gear, the motor housing could have a crack in it. The problem could be much more involved as well. Put the unit on the slowest speed and see if you can stop the mixer from spinning. If it hiccups or stutters, that means you have a stripped gear. If you cannot stop the unit using your hand ON THE SLOWEST speed then there could be a problem with the motor housing or the motor itself not being held in place properly.
Apr 02, 2012 | KitchenAid ProLine 600 Stand Mixer
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Mixer turns sometimes
The smell is the motor overheating and intermittant run is worn brushes in the motor
Jul 04, 2009 | KitchenAid K45SS Classic Stand Mixer
Professional 600 - makes loud noise when mixing,often stops as it blends 8 cups of bread flour and "needs a break", flat beater seems to get caught on bottom of bowl - this mixer is 1 yr. old!!
Several things:
The Professional 600 has a metal gear housing with a metal gearing. Because of this, the Professional 600 will generally run louder than other stand mixers that may have a nylon/metal mesh gearing.
How long is the bread dough being mixed for? Kitchenaid stand mixers must be used on speed 2 for bread doughs, using the spiral shaped dough hook, and mixing for no longer than 7 minutes.
If the flat beater is getting caught on the bottom of the bowl, pleasure assure the bowl is being seated correctly. You will place the bowl on the mixer arms on the left and right hand side. You will also want to take your fingers along the back of the bowl, where it butts up against the base of the mixer, and press downward. You will hear an audible click as the bowl falls into a spring latch and allows the bowl to sit flush and secure. If this is not being done, the flat beater may strike the bottom of the bowl.
If this was not the cause of the problem, please consult your Use and Care Guide about the beater to bowl adjustment. This is an easy adjustment made with a flat head screwdriver that can quickly correct the problem of a flat beater hitting the bottom of the bowl.
Jun 24, 2009 | KitchenAid Food Mixers
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Mar 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
HELP!!
The instructions advise to not run above speed 2 with the dough hook, making bread. This might be what caused it to be destroyed.
Mar 22, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
130 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
