Question about Krups XP604050 Coffee Maker and Espresso Machine, 10 Cup Combi
I have a combi Krups xp604050 and the frother does not work properly after a week. It boils the milk instead of frothing. I have cleaned it and still does the same thing. Help!
4 Suggested Answers
SOURCE: My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Posted on Apr 01, 2009
  • 56 Answers
SOURCE: no froth
Make sure the small metal tube is clean as well as the holes in mounts into. The tube can be removed easily from the rubber ends and cleaned. I've had my unit for a year now and we use it ever day without this issue ever happening. I did have the constant beeping water leaking from the seat/valve problem which I fixed by opening up the unit and tightening the screws.
Posted on Apr 15, 2009
  • 39 Answers
SOURCE: frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Posted on Dec 31, 2009
My nespresso aeroccino automatic milk frother is spinning and heating up but not frothing milk
I found that switching to a different milk solved my issue. It worked well with whole milk, but when I used Trader Joe's two percent organic it would not froth after .multiple tries. I borrowed a neighbor's creamer and it worked again.
Oct 13, 2012 | Nespresso Aeroccino Automatic Milk Frother
The frother on my krups 'il primo' has lost power. The steam barely comes out. How can I fix that?
I've also had this problem with the Krups 'Il Primo' - reduced steam for frothing of milk but plenty of espresso.
Diagnosis: over many uses, a residue of dried milk plugs the interior of the steamer tip.
Fix: Using a small adjustable wrench, remove the tip. Clean it inside and out with a tooth pick. Reattach the tip - gentle with the wrench.
Aug 01, 2012 | Coffee Makers & Espresso Machines
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues. http://www.cerinicoffee.com/rinza_urnex.asp
Also recommend frothing water instead of milk to clean the frother well.
For more information visit: http://www.cerinicoffee.com/Coffee_cleaning_supplies.asp
Jun 07, 2011 | Gaggia Brera Coffee Maker
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Hi I have a Spidem that goes very well untill
The frother is dirty from dry milk and probably it have been **** milk inside the valve. You can try to boil just water witha soop spoonful of cooking soda then leave it allnight long. The next day remove the palsic part and clean it well under runnging water and with a brush and also use the frother without anything so some of the dry milk will spit out. If you notice a diference then try this some more times. If you dont see any diferences than you need to desasemble it mechanicaly cleane the valve and pipe.
Good Luck
Please remeber to vote for this answer
Feb 27, 2010 | Spidem Trevi Automatic Espresso Machine
It doesn't froth properly
Trial and error solved the problem. The milk island is great but needs REGULAR cleaning. In order to clean properly one has to take apart the milk island and clean all rubber components of the dried milk that can and will accumulate. The most important cleaning taking place in all little holes as they are most likely to clog from the dried milk.
Jan 30, 2010 | Saeco Milk Island Automatic Frother -...
Apr 01, 2009 | Krups XP 4050 Espresso Machine
Aeroccino does not heat
Try descaling, if the element is covered with scale it wont produce enough heat and pressure.
The machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Oct 06, 2008 | Nespresso Aeroccino Automatic Milk Frother
Frother doesn't froth
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Need replacement frother part for Nespresso Aeroccino
both parts can be found on amazon for about 9.99$. take a look here: Secura Automatic Electric Milk Frother and Warmer Whisk Set. I hope this was helpful. cheers
Sep 02, 2008 | Nespresso Aeroccino Automatic Milk Frother
Krups XP604050 Coffee Maker and Espresso Machine, 10 Cup Combi Logo
71 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
