Question about Denon AVR-2803 Receiver
AVR 2803 shuts down when volume is medium or above
Is this a fuse problem? When watching a DVD or playing a CD the system shuts down and has to be reset when the volume is at medum or above, especially when the bass is heavy. I have to reset the system then turn down the volume for the system to play uninterupted. Until now I have had excellent performance from the AVR 2803. If this is a fuse issue and can I make the repair myself? Help - miss up boomin' bass.
Fred
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand it is not a fuse issue. If it were, then the receiver would be completely dead or will not sound at all.
Actually, this is more of a design feature, the purpose of which is to prevent the receiver from being over driven. If this "system shuts down" at that particular volume level has not happened before, then you may want to check the speakers, both continuity & grounding to basket/body as well as mechanical movement/action. If however, this "system shuts down" has happened since new, then you may want to lower down the volume a bit or the bass, or switch off the loudness. It may also help to reposition the speakers to your preference with the end view of getting the same sound distribution but on a lower volume level.
Worst case scenario are:
  • deteriorated speakers;
  • heat related issue on the receiver;
  • about to fail component/parts in the amplifier section of the receiver.
Good luck and Thank you for using FixYa.
Posted on Jan 03, 2009
  • 10,594 Answers
This is mismatch of speaker impedance hooked with receiver. Please remove all speakers and check one by one hooking back with receiver and give high volume to confirm what speaker exactly is cause of trouble. Receiver is fine and has no fuse problem.
    Genius:
  • 1,550 Answers
Yes it is fuse problem . Check the fuse whether it is blown . You can repair it with the help of service manual .
AVR-2803/983: Had recent 24hr Power Outage. When power restored, I receive no video/sound from TV thru COMCAST HD box, no video from CD but do get sound, lost partial use of Zone 2. Zone 2 works if I...
Extended power loss might lose memorized settings. Pretend the unit is brand new and verify all of them. No video from CD??? Really? Good luck with that.
Jul 16, 2011 | Denon AVR-2803 Receiver
Hello, I just hooked up our new PS3 Game system to our Denon 2803. Was happily playing it when it cut out on me after about 30 mins of playing. Turned the volume down to see if I was overloadingit but it...
looks like you are overheating it let it cool down for at least 20 min. and then when you use it just lower the volume, after that it should give you no more troble
Dec 18, 2009 | Denon AVR-2803 Receiver
Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Jan 17, 2009 | Denon AVR-3801 Receiver
My AVR 2803 shuts down when volume is at medium or above.
too big a speaker load,unit sensors shut unit down when speaker impedance gets too low . and draws too much current at hi volume.A bad woofer or tweeter voice coil burned by sudden excess volume can cause this,also partially shorted speaker wires.
Jan 03, 2009 | Denon AVR-2803 Receiver
When dvd plays radio comes through as well.
This unit needs to go out for service. There is an issue inside the circuitry in the unit.
Gary
Nov 22, 2008 | Denon AVR-2803 Receiver
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
Unresponsive remote
Had same problem with this reciever over the weekend. I had to hook up a TV to the COMPOSITE monitor jack and then I could see the menus. I could never get it to show the menu over the component outputs, however a DVD player hooked up played perfectly. Anyone have a solution?
Jan 21, 2008 | Denon AVR-2803 Receiver
Sound cuts out above medium volume
This is usually a heat problem. The more volume you ask of an amplifier, the greater the current (electrical) draw, the more current draw the more heat is generated. This is true of ALL electrical/electronic items.
As you describe it, the fuse is not blowing (stays on) so my choice would be a chip heating up and then shutting down. If that's the case (99% probabilty). The only other reason would be if the unit has an overload switch inside, it would react this way. Either way it's still a heat problem and truthfully nothing you can do.
Try this first though:
Is the Denon dusty inside? Dust can create 2 problems-heat and static electricity. Look through any vents you can get at. If the area around the unit is dusty chances are it is dusty inside. The best way to get the dust out is using a can of compressed air unless of course your vacum cleaner has a "blow" port.
In my shop, when heat is supected I use a can of freon th cool down chips, etc to isolate the component. This is not for a "layman" and strongly suggest bringing it into a shop.
One more question. If the unit using a knob for volume-do you hear a scrating noise when you hit the no volume zone? What happens if you go past the point quickly? I ask because sometimes there can be a bad spot on the volume. The volume knob is basically a circular resistor, whether digital or analog so this is a vague possibility (the other 1%).
If you e-mail me the serial number I can check with the Denon engineering department to see if there are any design problems as it may be a covered repair. It never hurts to ask.
Sorry to be the bearer of bad news
Jeff
Jan 09, 2008 | Denon AVR-2803 Receiver
Denon Avr 2803
Could be bad connection. Try to tight connection cables on receiver and TV.
Oct 15, 2007 | Denon AVR-2803 Receiver
Receiver shut down only when using phono preamp
You may want to try putting an attenuater in the line with the RCA's to cut the input signal back just a little bit. So you are not driving the amp so hard with your preamp.
Sep 08, 2006 | Denon AVR-2803 Receiver
Denon AVR-2803 Receiver Logo
47 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
