Question about Brother MFC-3240C All-In-One InkJet Printer
Problem printing on matte photo paper
I have tried with one sheet of matte photo paper and it won't **** it in. Tried semi-gloss paper and it worked fine. Can I use the matte paper with my printer Brother mfc-3240C. The paper is from printworks. It is 8mil
  • 10,865 Answers
You have to go into the menu and tell it which paper type you are using:
Setting the Paper Type
To get the best print quality, set the machine for the type of paper you
are using.
1 Press Menu/Set, 1, 2.
2 Press ▲ or ▼ to select
Plain, Inkjet, Glossy or Transprncy.
Press Menu/Set.
3 Press Stop/Exit.
Setting the Paper Size
You can use five sizes of paper for printing copies: Letter, Legal, A4,
A5, and 4" x 6" and three sizes for printing faxes: Letter, Legal and
A4. When you change the type of paper you load in the machine, you
will need to change the setting for Paper Size at the same time so
your machine can fit an incoming fax on the page.
1 Press Menu/Set, 1, 3.
Letter, Legal, A4, A5 or 4"x6".
Press Menu/Set.
3 Press Stop/Exit.
The machine ejects paper with printed surfaces face up onto the
paper tray in the front of the machine. When you use
transparencies or glossy paper, remove each sheet immediately
to prevent smudging or paper jams.
Posted on Jan 25, 2009
  • 685 Answers
No thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Posted on Jan 04, 2009
Why won't my Epson Printer XP405 print a photo on Epson Glossy Photo paper
Your printer may need you to replace the "matt black ink" with "gloss black ink".
May 19, 2015 | Epson Office Equipment & Supplies
Correct settings for printing on semi-gloss paper. I keep getting smears when printing and photo doesn't come out clearly
Well, it would be good to know why the photos are not good quality... like blurry or bad color or? Are you using a good paper? I have great luck with Canon glossy, and love the matte paper from Staples. Matte is actually easier and all around better color saturation, I find. I guess that you are using too much saturation of ink... see if your dialog box for printer options has a way to make saturation less intense. Also, I assume you are using the same dialog box to choose the type of paper. That is important, since different papers absorb ink at different speeds and amounts. I hope that helps... keep trying!
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
I have to clean my printer heads before I print any photo and after I stop awhile. Before I print again I have to clean the heads again because the photos are blurry and lines appear on my photos. I am...
Hi Juliet
EPSON STYLUS 1400 INKJET PRINTER PHOTO PAPER AND PRINTER SETTINGS
Formulating solutions based on remote diagnostics with just the detail in the question to go by is an inevitably imprecise science. We therefore aim to give our suggestions as wide an ambit as possible to cover all possible scenarios, abilities and experience levels. I suppose the best approach to initial FixYa solutions is to see them as an options list from which you can cherry pick the most relevant and practical ones. The Comment Box then provides the opportunity to fine tune the information flowing both ways. An updated picture after implementation of the relevant suggestions and additional background (such as whether the printer printed properly before and what paper choice of print setting changes since then may have caused the problem to first occurr, the remedies you have already tried, the specifications of you computer and its Opreating System) can then lead to more tailored suggestions.
There are many different types of Photo Paper and your Epson Printer has different Print Settings for each type. Matte paper, at the microscopic level, has more surface area than smoother papers and therefore has greater absorptive properties which, in turn, require a larger than usual amount of ink in order to produce an image with good resolution, than is the case for smoother papers. So Matte setting on a less absorbent paper type can cause excess ink issues and the problems you describe. The correct setting for each type of paper is the setting matching what is printed on the packaging of each respective type of paper (fabric, textured, matte, soft gloss, semi-gloss, gloss, high gloss, ultra gloss, premium gloss, etc).
Start > Control Panel > printers and faxes > right click on Epson Stylus 1400 icon > printing preferences > main > select 'Photo' or 'Best Photo' > click on the arrow next to 'Type' to reveal the drop down menu to select each Photo Paper Type you test > Apply > OK > restart printer > test Photo Printing again.
It is, for creative reasons, possible to deliberately use mismatched Photo Papers and Print Settings for artistic effect, but the results are unpredictable and matte settings for smoother, less absorbent papers can cause similar problems to those you describe. My advice to you would be to buy a variety of small packs of different papers to experiment with. Your enhanced aesthetic instincts will help you identify the best paper for the outcome you envisage. As a place to start, please consider examples of potential paper ideas by clicking on or copy/pasting-to-browser the links/URLs below:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=satin+photo+paper&x=17&y=13
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=satin+photo+paper&x=17&y=13#/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=fabric+photo+paper&rh=i%3Aaps%2Ck%3Afabric+photo+paper
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=satin+photo+paper&x=17&y=13#/ref=nb_sb_ss_i_0_20?url=search-alias%3Daps&field-keywords=textured+photo+paper&sprefix=textured+photo+paper&rh=i%3Aaps%2Ck%3Atextured+photo+paper
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=satin+photo+paper&x=17&y=13#/ref=nb_sb_ss_i_0_17?url=search-alias%3Daps&field-keywords=matte+photo+paper&sprefix=matte+photo+paper&rh=i%3Aaps%2Ck%3Amatte+photo+paper
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=satin+photo+paper&x=17&y=13#/ref=nb_sb_ss_i_0_17?url=search-alias%3Daps&field-keywords=gloss+photo+paper&sprefix=gloss+photo+paper&rh=i%3Aaps%2Ck%3Agloss+photo+paper
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=satin+photo+paper&x=17&y=13#/ref=nb_sb_ss_i_0_17?url=search-alias%3Daps&field-keywords=soft+gloss+photo+paper&rh=i%3Aaps%2Ck%3Asoft+gloss+photo+paper
So, please just set the printer settings to match each type of paper you trial to be 100% safe but there is also some margin for experimentation. With this in mind, you should be fine.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Oct 11, 2011 | Epson Stylus 1400 InkJet Photo Printer
Hi. my photo printing results is not so good on normal paper. plz tell me vat is the problem. i want to print photo in best resolution on ordinary paper.i.e (Double A paper)
Printing photos on ordinary paper do not come out well because the ink soaks into the paper like a blotter. I suggest you use semi-gloss or high gloss photo paper for best photo quality prints..
Feb 25, 2011 | Epson TM-T60 Printer
THE PRINTER WILL PRINT ON NORMAL PAPER BUT NOT ON kODAK PREMIUM P
Ok,, thanks again for the additional info. I had the same problem at one point with my HP photo printer, it seems the electronic eye that watches for the edge of the paper somehow can't see/focus on some of the high gloss papers.
How I tested it was simple. I roughed up(wrecking) one sheet and ran it through, it saw the page and printed. after that I tested with semi-gloss and it seems to work better.
Give that a try and let me know if that works.
Chris
May 27, 2009 | HP DeskJet 932c InkJet Printer
Epson stylus k3 r2400
Hi Lisa
The R2400 has the choice of two black inks, MK and PK. One is for Matt printing, the other (called photo black) is for gloss.
If the printer has the matt cartridge fitted it only allows suitable options, including paper choice, to be selected. If you change the black cartridge from the MK to the PK one, you should then have the choice of gloss paper.
Rich
Oct 04, 2008 | Epson Stylus Photo R2400 InkJet Printer
Epson C120/ Stops at Perforated line
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Quality Self-adhesive Sheets
Epson Premium Presentation Paper Matte Double-sided
Jan 23, 2008 | Epson Stylus C60 InkJet Printer
Printing
I wonder if it is in fact a printer problem? have you tried different programs?
Aug 18, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
241 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
