Question about Dell Office Equipment & Supplies
My dell V525w printer is making 2 inch black stripe on copies only (not printer jobs)
Print jobs are fine. but when I make a copy from the feeder or the glass, a 2 inch black horizontal stripe shows up
Nitrotrike
  • 589 Answers
SOURCE: Black line left on copies from the document feeder
Ah, the beauty of digital manipulation :)
In the old days you would have to change the paper in the tray too...
I've been looking online for the glass, and can't locate it. They will charge you a bundle for a piece of glass anyway (I know Konica charges about $50 one).
As to the question of a sensor. If there's no wire on it, there's no sensor. Some manufacturers use a "coating" that goes to a ground wire for anti-static, etc. Most likely, yours doesn't require this.
Also, to prolong the life of the new glass (now don't tell ALL of my secrets) use armor-all, car wax, even pledge (the wood stuff) on a rag and buff the glass. Just a dab will do.
I'll keep looking online for the part for ya.
Posted on Feb 15, 2008
SOURCE: HP J5780 All in one printer
When i try to make a copy, it printing out just only whole page black color even ,I put color button.Why.
Posted on Nov 29, 2008
antiochpc
  • 1314 Answers
SOURCE: vertical black line in scan document not in copies through document feeder
Lift the lid and to the left of the main glass is a smaller glass; that is what scans during the feeding process. Make sure that it is completely clean; even a speck of dust can cause a line to appear. I took a lens wipe and cleaned mine and my line was gone.
Posted on Jun 01, 2009
SOURCE: HP 7410 streaks when using auto document feeder to make copies
Lift the cover of the fax/scanner/copier. The glass area has 2 sections, a small section and a large section. Clean the small glass section with damp cloth. I had 3 black streaks caused by 3 black dots on that glass. I also cleaned the rollers on the ADF, but that was not the problem.
Posted on Jun 27, 2009
SOURCE: When I use the feeder
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Posted on Feb 17, 2011
WHEN I MAKE COPY OR PRINT THE PRINTED PAGE IS NOT CLEAR, IT HAS SOME VERTICAL LINE ON LEFT SIDE AND SOME DOTTS ON RIGHTY SIDE, WHAT SHOULD I DO SOLVE THESE PROBLEM?
For copy jobs, clean the glass with a soft clean cloth, regularly, not just the 8.5 x 11 screen but the 11-inch x .5 inch strip that copies when using the document feeder. Print job: their is probably dirt or ink on the rolling parts. Q-tips are good for cleaning this up, careful, don't burn your fingers.
Mar 27, 2012 | Canon FAX-L400 All-In-One Laser Printer
Panasonic dp3010 copier stripes on paper
Not exactly sure what you are asking but if the problem is that you are getting fine lines down the paper (the copy is ok though) then take a real close look atr the glass platen (the plate glass in which the paper goes on. Assuming you are using the ADF (Automatic Document Feeder) area. This area is usually about an inch wide by 8.5" long. Look for either "White out" or black ink on the glass (it can be as small as a dot) clean this mark off with glass cleaner and you problem will be solved. Sometimes it helps to orientate your copy with the line on it to the machine to locate the mark causing the issue.
Good Luck!
Mar 01, 2012 | Office Equipment & Supplies
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
Toshiba eStudio 2830c-getting a light line across
Hello sir; Is the stripes allway in same place and you use document feeder to copy, then you have to clean up a piece stripe glass on the plateform, otherwise ,you have to change drum cleaning blade or drum cartridge.
Dec 24, 2009 | Toshiba Office Equipment & Supplies
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Error 9-363
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
125 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
