Question about Honda 3000 Watt Portable Generator
Honda eg 2500 generator wont start can it be shut off switch
Ive cleaned carb its good it looks like no spark
  • 52 Answers
SOURCE: gas in the oil on my honda generator
Your needle/float is stuck, which will allow fuel to flow though the intake...past the piston..and into the crankcase. If has been awhile since you used it, most likely the gas has gummed up the insides of the carb. Otherwise, you may have had something get into the fuel bowl that is keeping the needle from closing. Best way to solve is to remove and clean the carb. Replace fuel filter if needed also.
Hope this helps
Posted on Mar 11, 2009
buffalonyman
  • 1865 Answers
SOURCE: Honda EG 2200 Generator wont Start
First make sure that you have a spark; remove the spark plug and position it so that the threads are touching the engine frame. Pull the cord and check the plug for spark. If you have spark, put the plug back in.
Get some starting fluid and spray it into the air intake of the carbuerator. Try to start the engine. If it starts and then stops, that indicates that you have a fuel delivery problem. Clean the fuel filter.
Posted on May 31, 2009
  • 8404 Answers
SOURCE: honda ex3500 generating no voltage at all. oil is
Is this a new device for you or have you used it in the past?
Generic comments follow:
In my experience, there is a switch that ya turn off to start the device and allow it to warm up. Following this short period, ya turn this switch to the on position and a governor takes over - slows the engine to an idle until it sees a load at which time it runs the engine speed up. In the off position, the generator part of this combo is turned off.
In my experience, the protection devices on small generators are auto reset.
Let me know if this works for you.
thanks
a
Posted on Sep 23, 2009
  • 274 Answers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
  • 151 Answers
SOURCE: honda ex1000 wont start cleaned carb disconected
drain the fuel,replace with fresh
Posted on Dec 24, 2009
I hav a 1995 honda cr 125 it has spark and is getting fuel and wont start but back fires the odd kick, ive replaced ign control, cdi box, rotor and generator, coil and plug
check compression, the valves may need adjustment. also make sure that the carb is clean and that there are no air leaks or you will have trouble. From my experience, 80% of old bike troubles come from the carbs being dirty/clogged. Pull the carb off, disassemble any plastic/rubber parts and BOIL in lemon juice for 20 minutes then rinse and blow out the passages. Reinstall and give it a try. If the valves are out of whack then the piston wont compress the air/fuel mixture and the spark will not ignite the mixture or will ignite it erratically thus getting an occasional backfire. Check valve lash and retry.
Dec 05, 2010 | Honda CR 125 R Motorcycles
I have an em3500 honda generator which starts stalling out after 1/2 hour to an hour like it is running out of gas and then shuts off. I can restart it and it will run for 1/2 hour to hour and do the same...
Recheck for spark when it stalls. If you have lost spark I would say a heat damaged coil.
You should also drain and inspect the carb bowl. You may have low fuel flow which limits full throttle operation to 30 minutes or less. When it dies you are just refilling the bowl for the next run.
Good luck and be careful!
Aug 10, 2010 | Honda 3000 Watt Portable Generator
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
Oct 28, 2009 | Coleman Powermate Powermate 5000W...
Wont start has spark , new fuel, new oil.
Is the spark plug black?
It won't run well with a carbonized plug.
Is the main jet in the carb plugged?
If the plug is dry after trying to start it.....your fuel is not getting into the engine and most likely a plugged carb jet..
Also.....Is the fuel switch working...is it in run position?
If the generator has sat for a while with fuel left in the carb/fuel tank.......the most common problem is a plugged varnished dirty carburetor in need of a good cleaning.
Always shut the fuel off and let the carb run dry (run until the engine stops)before storing.
Add fuel stabilizer to any remaining fuel or drain the tank before storing.
Oct 14, 2009 | Honda Electrical Supplies
May 31, 2009 | Honda Electrical Supplies
Help !
hi m8,, usually if the cdi is playing up u wont have a spark at all,, has the carb been cleaned out, ,,id look at the 1st,, ,clean the jet out ,,and any brown residue,, pull off the plug cap from the spark plug,, ,, then unscrew the cap and just snip a little bit of the ht wire off,, so u see a copper lookin bit of wire pokin out the middle of the black ht wire,, then screw the cap back on,, try this 1st m8,,
May 01, 2009 | 1985 Honda XL 125 R
Honda 3000 Watt  Portable Generator Logo
111 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
