Question about Kenmore 15516 Mechanical Sewing Machine
The foot on my Kenmore sewing machine model 15516 was removed and I cant get it back on.
    Scholar:
  • 69 Answers
If it is a snap on foot, just line up the bar with the "hook" on the shank and drop the presser foot lever into the down position, it should snap back into place.
Posted on Feb 12, 2009
Bought at thrift sale with no owners manual can you help me find a website that i can order one by looking at the machine? It was a home ec machine so i have no idenification on it
If it has no identification, you are stuck. By law, there has to be a plate that tells you the voltage and amperage. The makers name will be on that. This will be close to the motor. Also so if anything is embossed into the foot pedal. If we have at least a make, we can start. Reply back as a COMMENT.
May 03, 2016 | Kenmore 15516 Mechanical Sewing Machine
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
I can not seem to thread my Kenmore 15516
hi there,
this will a great help to you, type on search box www.youtube.com on search box type Kenmore 15516 sewing machine repair,this will show you how to thread and adjust dial tension as will stiches.happ sewing regards
Jul 06, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Feb 20, 2009 | Kenmore 15516 Mechanical Sewing Machine
Can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Feb 14, 2009 | Kenmore 15516 Mechanical Sewing Machine
Sewing machine
You may need to remove the shank shaft w/screw driver which is where the foot attaches to and replace it . I had a problem when I had to attach a ruffler foot. A little practice w.this can save you a lot of repair bills. Most Janome dealers can repair ths too. Kenmores are made by Janome.
Oct 17, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 15516 bobbin
1. Remove the bobbin case
2. Release the clutch by pulling out the handwheel
3. Draw the thread from the spool andguide the thread throught the hole in the bobbin from the inside to the outside
4. Put the bobbin on the bobbin spindle
5. Push the bobbin to the right
6. Hold the free end of the thread and depress the foot control, wind until full
7. Push the handwheel in (to wngage the clutch)
8. Push the bobbin spindle back tot he left to resume sewing mode.
9. Place the bobbin in the bobbin case (thread should feed clockwise)
10. Draw the thread through the slot in the bobbin case
11. Continue to draw the thread under the tension spring and through the opening Pull out about 4"' of thread
12. Holding the latch open position the bobbin case into the shuttle and release the latch
13. Case should lock into place when released
Hope this helps!
Bonnie
Sep 27, 2008 | Kenmore 15516 Mechanical Sewing Machine
Problem with my machine
If you're not picking up a bobbin thread, it's either a timing issue, or the hook/needle clearance. Usually, with the hook/needle clearance the skipping stitch problem will be intermittent. If it's a timing issue, it may not pick up the bobbin at all.
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Cant put back together
Upload some photos of your machine, showing where you removed the parts from, also showing the parts you removed,
and I''ll guide you how to put them back.
Jun 09, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
43 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
