Question about Rockford Fosgate Punch P3002 Car Audio Amplifier
Want to look up information by serial number
I have a rockford fosgate amp and want to know how many watts by serial number
5 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
laseramp
  • 314 Answers
SOURCE: 401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
the problem is mostly with your audio side of the amp. i have a 800 Rockford punch series amp hooked in series running at about 15 vdc at 2 ohms stable for now. but the amps left front power side transistors overloaded and smoked out, i will be replaceing my mosfets soon. Now on that side your issues apear to be related to the signal side of the amp. when you hooked the amp up tell me breifly did you hook the rca inputs to the back of the sterio and did you select the proper rca inputs for the amp? also note that amps have a potentiomater that can be tuned up or down to allow the volume or wattage to go up or down threw the system. if it's turned all the way down you'll here nothing. but often you'll get a pop sound or quickly see the speaker move a bit. this indicated the signal side of the amp has signal comming in but no output, just look for a turnable small screw inside the amp top or side. and turn up acordingly. note: to much output will damadge your system. not just the amp. ;)
Posted on Aug 28, 2009
Professor_V
  • 92 Answers
SOURCE: Rockford Fosgate Punch End CapsEnd Caps
I TAKE IT THAT YOU ARE REQUESTING A SOURCE FOR A PAIR OF ENDCAPS FOR YOUR PUNCH-200IX. IF THIS IS THE CASE, I SUGGEST THAT YOU CHECK EBAY ON A WEEKLY BASIS AS I AM SURE AFTER SOME TIME, YOU WILL SEE A PAIR LISTED. THERE IS ALSO A SELLER ON EBAY THAT HAS MANY OF THE LOGOS FOR THE MANY DIFFERENT MODELS THAT CAN BE PLACED ON ANY OTHER MODEL ENDCAPS FROM THE SAME SERIES (DSM, IX, X2, ETC. LET ME KNOW IF I MISUNDERSTOOD YOUR REQUEST......V
Posted on Jan 06, 2010
joshter32
  • 82 Answers
SOURCE: wire my rockford fosgate rf2002 amp and 12"sub to cobalt
Hi my names Josh. I see you want put your rockford amp in. Assuming you have your factory radio you have some wiring to do. But first you need and amp kit it wil have the necessary wiring you will need in it to wire your amp to your car. You will also need a line level converter they you can pick on up at best buy other wise known as a pac converter. This will alow you to transfer the high level frenquency your radio puts out to a low level frenquency to go strait to your amp through a pair of RCA's thus giving you sound to your amp and then to the sub. Your wiring will consist of the ground which you will have to ground off the vehicles chasis no more than a foot from your amps designated location. Then you have you power 12v which is about a 4 gauge wire and will be fuzed and ran strait to the positive side of your battery and last will be your remote wire. Your amp will have a place marked remote on it that is strickly for you to wire to your radio/ignition source for powering the amp up when radio is on and powering it down when it is off. YOU MUST ISOLATE THAT WIRE with a 12 volt tester it will be the wire that is tied in to your radio to power only when your igniton is on and when you turn your key it should tell you if you know how to properly check for this wire. wants you istolate this wire you will want to tie into to it and then of coarse run it and tie it into your amps remote power again it will be marked remote on your amp. From there all you have left is tying in your line level convererter.. This takes some patience as you must make sure that you do isolate your sound left and right postive and negetive front and rear channels the line level converter will tie into either your front or rear channel but caution you dont get them mixed or you will not have a signal at all. Again my names Josh and i hope you are able to get it hooked up okay.
Posted on Mar 07, 2010
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Apr 03, 2015 | Rockford Fosgate Car Audio & Video
I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
Your amp is rated at 500 watts. Here is the break down of your wattage.
125x2 at 4 ohms
250x2 at 2 ohms
500x1 at bridged 4 ohms
When hooking up the amp make sure to use 4 gauge power and ground wire.
Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
Need to know how many ohms this amp is
Safe down to 2 ohms, NOT a 1 ohm stable amp, it will be pushing it hard even at 2ohms but Fosgate's should be able to handle it providing that the install and all cables,wire,connections,etc. are sanitary!
Good Luck !
Jun 30, 2010 | Rockford Fosgate Punch 301S Car Audio...
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
Amps that work with 10" RFZ2410
well how manny amps can the sub hold? any amp will work you can bridge it to doulbe the power but i would say a 200 wat amp would do you good
Aug 02, 2009 | Rockford Fosgate RFZ2410 Car Subwoofer
I dont know what my amp wattage is
It's a 200 watt amp. RF for Rockford Fosgate 200 for 200 for 200 watts and 2 for it being a 2 channel amp.
Jun 27, 2009 | Car Audio & Video
Hello desperate2le,
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Rockford Fosgate Punch P3002 Car Audio Amplifier Logo
235 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
