Question about Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher
Water pours from the vent located on the sink near the faucet.
What can we do to prevent water pouring from the dishwasher vent when the dishwasher is emptying?
  • Stephen Gomez Jan 03, 2009
    This is a recent development - the water pours out the vent under pressure when the dishwasher is emptying.
    President:
  • 2,976 Answers
Make sure the 'T' where the dishwasher is connected is directing the water downward. also, if this isn't the issue, move the 'T' to the other drain pipe. If the 'T' is too close to the vent, you will get back pressure and it will come out. The less resistance the better.
Posted on Jan 03, 2009
Dishwasher not draining
if your washer is installed correct your sink has an "air gap" that could need cleaned ( on sink top next to faucet theres a short stubby silver cap) under this is a plastic cap that unscrews (dont run washer with this off water will come out ) try pouring a bit of water down hole if it is blocked your air gap is plugged this will require a plumber to dissasemble it to clean it off
Feb 19, 2015 | Dishwashers
Installed a new KWC Domo faucet and its leaking (alot) under the sink
Does if have a sprayer and is it still hooked up?
Aug 14, 2014 | Plumbing
New kwc domo leaking under (alot) sink
mixing chamber of the faucet may be cracked
Clogged Bosch SHU 9920 dishwasher
-Sounds like the pump is not working properly or the drain line you connect to sink directly instead to the breath cap before to the sink. Or the breath cap locate too low.
-Make sure the breath cap is mount higher than the line to the sink. (Or as high as possible) This is to prevent any water from the sink pour into the dishwasher.
Good luck
Mai
Jun 16, 2017 | Bosch 23 in. SHU 8805 Built-in Dishwasher
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Water continually pours out of right side bottom
water continually pours out right side lower vent.dishwasher won't do anything else. no display lights on console.
May 05, 2010 | Viking DFUD042P Built-in Dishwasher
Soap is coming out of the faucet when the dishwasher is on.
connect the drain to the correct disposal pipe
Dec 14, 2017 | Frigidaire Dishwashers
How do you reset the kenmore elite dishwasher? I replaced the faucet in my sink and forgot to turn on the water to the dishwasher....when I started it it went half way through the cycle when I realized...
Turn off the breaker that powers it. If all else fails, take a jug, fill it in the sink and pour it into the bottom of the dishwashwer until it comes to the bottom of the heater, that's the round think suspended above the bottom, below the rack, and turn it back on.
Sep 08, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I have started hearing a gurgling sound in my diswasher air vent when I run water in my sink. Why has this begun happening? I have an /estate dishwasher Model TUD7000Y-0
Sounds like your waste water drains could be backing up and pushing water back into the dishwasher.
Firstly try pouring Mr Muscle sink and plughole un-blocker down the sink and leave overnight next morning pour boiling water down the sink and your pipes should be squeaky clean. Hopefully this will improve the flow and prevent gurgling!
Feb 21, 2009 | Miele 24 in. G870 Built-in Dishwasher
Non return valve
Has it always done this? If so it was an install issue. The tech should have put the drain above the drain with a loop to prevent backfill.
Jan 26, 2009 | Dishwashers
Maytag 24 in. MDB6600A Jetclean II Built-in Dishwasher Logo
160 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
