Question about Panasonic Televison & Video
The words "nav" are displayed in the display window. I can't get rid of them or record or playback.
It is a Panasonic DVD Recorder DMR-XW450 or DMR-XW350
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
nandosnut
  • 112 Answers
SOURCE: panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Posted on Apr 24, 2009
SOURCE: panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Posted on Jul 01, 2009
SOURCE: U88 displayed on dmr es15 panasonic dvd recorder.
Took off casing ,removed dvd unit. The laser runs along 2 metal spindles which i lightly oiled with wd 40. next to it runs another brass spindle which i also oiled. Re-assembled , and the machine is good as new.
Posted on Nov 16, 2009
Hi My Panasonic DMR-E85H Won't let me record to the Hard Drive it is displaying NO REC message on the Display ? Any ideas are most welcome .
it's the same problem with panasonic dmr-e55 recorder ; must we slack them for another one !!! we need help seriously
Jan 13, 2013 | Panasonic DMR-E85H DVD Recorder
The display shows the message "HOLD" by pressing
I have the same problem like monika_sadzi on Dec 23, 2010
Panasonic DMR-E95HS DVD Recorder
The display shows the message "HOLD" by pressing any key.
Dec 23, 2010 | Panasonic DMR-E95HS DVD Recorder
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
Have a Panasonic DMR that will not work, keeps showing U61 code
u 61 means-displays when a malfunction has occurred,playback or copy.this is displayed when the unit is in the recovery process to return to normal operation,it is not broken.once the display disappears you can use the unit again.
Apr 26, 2010 | Panasonic DMR-E55 DVD Recorder
My Panasonic DVD recorder DMR-E60 doe not respond to its remote control. IT display DVD 2!
Nov 24, 2009 | Panasonic DMR-E60 DVD Recorder
Panasonic DVD recorder won't recognize any disk inserted in tray
I am just wondering if you found the solution to this problem as it has happened to ours.
Regards
Oct 11, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
I have a panasonic dmr-xw450 hd recorder which i was promised would record directly to disc. i cant make it do so. i have tried dvd-rw and dvd-r discs to no avail. not very happy with the store or...
Are you sure this records directly to DVD discs?. I did a search and could not find conformation of that does your owner's book confirm it? I know this is a top of the line DVR but confirm it.I did see plenty on the complicated Remote the answer may be with it.Good Luck.
Sep 09, 2009 | Televison & Video
The display keeps saying please wait. I unplugged the unit and plugged it back in and it still displays please wait.
The display keeps saying please wait. I unplugged it a million times. Please help me resolve this problem.
Aug 01, 2009 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR EH56 permanent U88 Error on DVD- and HDD-Drive
displays when ther was somthing unusal detected with the disc while recoding playback or copy this is diplayed when the unit is in the recovery process to return to normal operation the unit is not broken once the display clears you can use the unit again
Jul 14, 2009 | Panasonic DMR-E55 DVD Recorder
PANASONIC DMR-E55 DVD RECORDER
Try first unplugging unit from main, and holding the cancel button.
If that does not work try the following:
Hold at the same time the stop button on the main unit and key >10 on the remote control at the same time for about 5 seconds, until you get the word "initialised" on display. This will reset the unit to factory settings.
Jan 25, 2008 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
89 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
