Question about GE Profile JB968 Electric Kitchen Range
GE Profile JB 968 Hot Cooktop Indicator Light Always On
The warming zone hot cooktop light is always "on" on the glass cooktop. How do you get the light to go off?
  • shop594 Mar 05, 2009
    The "hot cooktop" light for the front right (main) burner won't turn off. Does anyone have a solution for this?
Temporary solution to turn off the indicator lamp - put a wet rag with an ice pack on top on the middle section of the cooktop.
The thermal sensor will trip off the lamp.
Posted on Apr 24, 2009
Can the glass of a whirlpool cerano hob suddenly crack?
You didn't need 'red hot' to simmer. When you got it red hot, and then put the pan on it, the pan sucked the heat out of the ring to fast, and caused stress in the glass causing it to crack. Tops are meant to be used the way you used it. Your fault I am afraid.
The top can be replaced.
Sep 19, 2016 | Whirlpool 30" Schott Ceran Surface...
Why is bulb so hot on cooktop light on Kenmore Elite Microwave Hood combination
depending on the type of bulb ( sounds like a halogen? ) turn it off for cleaning
Jun 26, 2014 | Kenmore Microwave Ovens
Hot surface light stays on on GE Profile Cooktop model JP989 and On does not light for left burners. This is only happening on left burners. Left front burner goes to high with any setting on the switch...
You could have a shorted burner, if it is not then you may have gotten a bad part.
always unplug electricity before attempting to repair on any electrical appliance
Aug 17, 2017 | GE 30 in. Profile JP989 Electric Cooktop
GE Profile GSP40 cooktop hot burner indicator wont light up
This is obviously a loose connection in the panel that is flexed when you put pressure on the top. The rear panel needs to be opened and checked.
Jan 22, 2013 | Cameras
The unit light (not the hot surface indicator light) in my GE Profile ceramic cooktop does not turn off although the burners are off.
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Sep 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
I have a whirlpool glass top stove and the cooktop light will not go off.
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Feb 19, 2011 | Whirlpool Microwave Ovens
GE Profile JB968 Electric Kitchen Range Logo
1,259 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
