Question about Bosch Washing Machines
What is the sanitary cycle on my bosch axxis washer
3 Suggested Answers
uniman9310
  • 189 Answers
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
Posted on Jun 03, 2009
SOURCE: Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
Posted on Jun 24, 2009
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Just bought the Bosche Axxis front loader. When the spin cycle kicks in, the machine wobbles/shakes/wanders VIOLENTLY from side to side. Is it the installation or the machine?
I bought the Bosch 8Kg washing machine on 8th Feb, I had the same problem.
Read installation instructions, you need to remove transport safety nuts from the back.
Feb 06, 2011 | Bosch Axxis WFL 2060 Front Load Washer
How do i deactivate the child lock on the bosch axxis washer
Hi
To unlock the washer press and hold 'dry' & 'spin' button. It should unlock now. If this doesn't work then press and hold "end of cycle" button for 5-10 seconds. However, if it is still locked then unplug the washer for 5 minutes and then plug it back. After plugging it back press and hold Start button for 10 seconds to unlock it. Hope this helps...
Daniel
Aug 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer leaking
First of all check the outer lip of the doorseal. It must be damage freein the lower half of the door opening. Then lift the folded part of the lip which faces towards the drum. Examine the doorseal with a torch. If any holes are evident the doorseal must be replaced. If you are in melbourne metro area you can call me on 0417362396.
Regards Sam
Jun 16, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
458 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
