I have a lasko ceramic element heater model 5805 it does not come on when I push to power button
I got it last year and it was working fine then it just stop comeing on
hotuna
  • 288 Answers
SOURCE: LASKO model 5400 ceramic heater
The contact are just a set of points. If you can remove them, file or sand, or whatever will do the job, a little on the place where the contacts touch. Usually that's all it takes. Make sure when the switch is turned on the lever/spring assembly moves and at least tries to make them touch. I don't really see a problem with directly wiring the fan. The only drawback is there is no real control except pulling the plug.
Posted on Mar 05, 2008
bigjohn007
  • 425 Answers
SOURCE: I just purchased a lasko model 5805 ceramic
look for the power rating of your heater (usually it is in Watts (W) and convert it to kilo Watts (kW) unit by diving it by 1000).
kW = W / 1000.
now divide the kW by hour many hours your planning to operate your unit.
power consumption = kW/operating hours
when you get your power consumption value then multiply it with the power cost (you can find it usually in your bill).
cost to operate = power consumption x power cost.
Happy New YEAR!!!!
don't forget to rate me...
Posted on Jan 01, 2011
markfreedman
  • 312 Answers
SOURCE: My Lasko 5805 heater worked
Hi, I looked through the manual for the information to change the thermostat display from reading Celsius to Fahrenheit. Couldn't find anything. I did find a number to call for customer service
800-233-0268
Also, Here is the link to the manual.
http://www.laskoproducts.com/instructions/5800Ins5800ESa.pdf
Hope this Helps,
Happy New Year,
Mark
Posted on Jan 02, 2011
SOURCE: The lasko ceramic element fell
Unplug it for 5-10 minutes. Then try again, worked for me. Plus it says to do so in the back of unit! Hope this helped
Posted on Feb 13, 2011
  • 4736 Answers
SOURCE: i have model 5805 and
Sounds like the ceramic heater has lost it's ability to heat completely. In other words, it doesn't peak any more.
Can it be repaired? Possibly, but finding the part(s) may prove difficult. However, if you can safely disassemble the heater, I would recommend that you try cleaning the interior with a can of compressed air that has a straw nozzle (like you clean your computer with). It may simply be a case that it's clogged with dust and lint. Try not to disturb any of the electrical parts when you do this.
Hope this helps solve your problem.
Posted on Feb 28, 2011
The on/off switch no longer works
check the bottom of heater for a push button type switch that is supposed to sense that the unit is upright ...also try it on a solid flat surface
Jan 18, 2014 | Lasko Heating & Cooling
I do not have a problem i need a manual or instructions on useing this heater for lasko ceramic element model #751320
Here is an email address for the Lasko Products Help Dept. They should be able to provide that for you. producthelp@laskoproducts.com If you prefer to call them the number is 800-233-0268.
Hope this helped you.
Mar 09, 2011 | Lasko 751320 Ceramic Heater
I have model 5805 and i seems to always run, never shuts off and doesn't get my childrens small room warm (10x10) thought room wasn't holding heat so i put my lasko tower heater in there and it worked just...
Feb 28, 2011 | Lasko (7564) Heater
My Lasko 5805 heater worked fine and still works fine except the temperature shown is now in celius instead of farinheight
800-233-0268
Hope this Helps,
Happy New Year,
Mark
Jan 02, 2011 | Lasko Ceramic Heater
I just purchased a lasko model 5805 ceramic heater. What's the cost to operate.
kW = W / 1000.
Happy New YEAR!!!!
Dec 31, 2010 | Lasko Ceramic Heater
Hi, I have the Lasko Ceramic Elements heaters. When I plug it in, the light lights up to show it's plugged in, but when I try to press the POWER button turn it on, it beeps but does not do start heating...
If I am getting this right you just purchased this heater? I would return it and get another one. It sounds like the tip over switch is not made and will only show that power is getting to it but the tip switch is keeping it from heating.
Dec 14, 2010 | Lasko 5540 Ceramic Compact Heater
It makes a lot of noise and its dirty inside. I just wanted to know the best way to clean it
use a compressor and a blow gun attachment blow the air thru the fan opening then back thru the heating elements do this several times back and fort until you get no more dust from the heating elements. I have done this on my own heater and it works just fine. Try this and you will find yourself cleaning the heaters each year this way with out taking them apart.
Dec 13, 2010 | Lasko 5367 Ceramic Heater
I have a lasko tower ceramic heater that keeps shutting down.
mine does the same thing every year. I just clean out the dust from the vents on the back of the heater so the heater can breath otherwise it could get too hot and the safety fetcher kick in and makes the heater stop working.
Oct 19, 2009 | Tower Lasko 30 Inch Ceramic Oscillating...
Have a lasko ceramic element heater
just wanted to say that I am having the same problem.  I turn it on and it stops working.  When I push the power, it only lights up for a second and beeps and then goes off.  Is there a solution to this yet? I think the company owes us an explanation.  I have already tried to plug it in to different outlets and still get the same results.
Dec 01, 2008 | Lasko Ceramic Heater w/Adjustable...
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
