Question about Apple iMac G5 MA064LL/A Desktop
IMAC G5 DVD-ROM slot keeps ejecting disks
Slot will not hold any disks.  It sounds like it is reading the disk and then ejects.
  • 1 more comment
  • toots6712 Jan 03, 2009
    I tried cleaning with a cleaning disk...but it ejects the cleaning disk.
  • ralphkupper Mar 19, 2009
    Apple iMac 2,8 GHz Core 2 Duo w/OS X 10.5 Ejects all CDs & DVDs
  • Anonymous Mar 28, 2014
    I did not eject my photo card properly from the iMac and when i put it back it was just floating. Managed to remove it with tweezers. Did I break the spring load? How do I fix it?
  • 558 Answers
The drive is bad you will have to replace it.
Posted on Sep 16, 2009
  • 86 Answers
Try cleaning the lens or the drive with a cleaning disk
Posted on Jan 03, 2009
My imac dvd drive reads DVDs but ejects CDs and installation disc
The optical drive has separate hardware for reading CD-disks and for reading DVD-disks.
So, "half" of the drive has failed. Replace the drive, since that will be less-expensive than an attempt at a repair.
Jan 15, 2011 | Apple iMac HD, CD-ROM / DVD-ROM Carrier...
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
I've a DELLXPS M1530. I'm trying to eject a CD, wont come out
I do believe that there is still a small hole by that slot, that you can insert a straightened paper Clip into, and keep pushing until you feel/hear a slight, click, keep pushing gently and the disk should soon appear. IF you cannot do that the DVD will be removable by taking out the fasteners underneath the laptop,, and sliding the DVD out. for repair of replacement.
Mar 04, 2010 | Dell XPS M1530 Laptop
I have a laptop that doesn't have eject button for slot cd player
go to Dektop / My Computer
right click
u will c all the drives....i mean..... c: d: etc
locate ur CD/DVD rom drive,..letter...d: or e: etc..
select ur CD/DVD rom drive
right click and chose option Eject...
u r set...
Dec 20, 2009 | Toshiba Sattelite A105-S2051 Notebook
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
Oct 10, 2009 | Apple iMac G4 Desktop
How i eject a stuck cd from a imac
The front of the CD Driver you can see a very small hole…use a safety pin and open it then insert the pin in that hole and push it in that will force the door on the CD to open …Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Apple iMac G5 Desktop
Dirty DVD Drive?
You can clean your DVD Drive by inserting the Disk Cleaner its either dry or liquid cleaner. If you don't have a disk cleaner just purchase it in the store near in your neighborhood. In that way you can clean the DVD Drive Laser eye and make it possible to read another disk next time you used. Usually it takes 15 minutes the standard cleaning time if you are cleaning the DVD Drive to ensure that it is properly cleaned. Also if it doesn't work then probably you can find a technician and let it check to the technician. I hoe that the laser eye of your DVD Drive is not damage due to some disk you inserted earlier.
Hope this recommendation helps solved your problem.
If you need more assistance just reply to this post. thanks
Jun 26, 2009 | Apple 24" iMac Desktop
Won't start up....emergency eject????
As soon as you turn on your G5, hold down the mouse button. Keep holding it down until the disc ejects. Make sure you hold down the mouse button (right side or middle) as soon as you turn the computer on.
Apr 28, 2009 | Apple iMac G5 MA064LL/A Desktop
Apple iMac G5 MA064LL/A Desktop Logo
1,969 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
