Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Lost ring inside washer/dryer
Older product, actually model number LSQ9110LW0. Can't find my wedding ring. I remember it being in my pants pocket. House has been checked with a fine tooth comb. Also, may be in dryer. Dryer is a Whirlpool Ultimate Care II, model number: LEQ9508LW0. Please help!!
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
I am betting it is in the dryer. Here is a video to show you how to open it. Please let me know if you find it in there. Look thru the COMPLETE duct work and blower. I doubt it is in the washer. If it is, it is under the agitator.
If you should need any further help, please visit http://appliancecafe.com/phpbb/ and register to login to the forum.
Good Luck!
Posted on Oct 30, 2012
Testimonial: "took the dryer apart with no problems, ring was not in there. However, it was in my pants pocket. I was 100% sure I wore my brown pants which were in the washer. I however wore some blue pants which were only worn to run to the store to get milk and propane. Put the rings in my pocket once I got home to wash my hands and they found their way into the closet. Silly me! Thanks for the help though. I found them a few days ago but at least now I know how to take my dryer apart.!! :)"
  • Richard Roth
    Richard Roth Nov 23, 2012
    I am so glad you found them! Thanks for using FixYa!
  • 60 Answers
SOURCE: Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Posted on Nov 09, 2008
  • 116 Answers
SOURCE: whirlpool ultimate care II lost item in washer or dryer
It is most likely that they are in the dryer if you still have not found them. Please respond with the type of dryer that you have and I should be able to assist you in opening your machine for a good look. From what you have describe it sounds like you have an Inglis or speed queen dryer.
Posted on Mar 11, 2007
mikedurland
  • 481 Answers
SOURCE: Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Posted on Jul 15, 2008
honeymokey
  • 3113 Answers
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Posted on Jun 18, 2009
washdryman
  • 154 Answers
SOURCE: Upper agitator on Whirlpool Ultimate Care II washer
replace agitator "dogs"
Posted on Mar 01, 2010
I need to know if Maytag Centennial washers have a drain screen in them? my wife may have lost her wedding ring in them.
Need the model number of the washer, if it is front loader the answer is yes it would have a screen at the inlet to the drain pump.
Jan 24, 2017 | Maytag Washing Machines
I have a WTW5600XW Cabrio Electric Dryer and a WTW5640XW Top load Washer. I have lost my ring and think it may be in either one of these. I think I forgot it in my pants pocket when I put it in ther
In the washer it could be under the agitator if it is a top loader, if it is a front loader there is really no place for it to go but check the rubber seal around the door. In the dryer it should be in the tumbler or possibly in the lint filter but unless the lint screen is broken or you ran it without one it should not be able to go out into the venting piping etc
Sep 19, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Lost engagement ring in washer dryer
Check the hoses at the base of the water pump.They could stil be there.
Jan 06, 2014 | Candy Washing Machines
I have a whirlpool washer and dryer model # LTE5243DQ6. I have recently lost my diamond ring that I last remember putting in my pocket. I think it might have gone through the washer or dryer. Ive checked...
it could be between the two bowls, or down into the waste pipe, where some models have a catcher for items like rings and coins.getting to it will require some disassembling that might be best done by someone who knows how it goes back together.
Nov 11, 2013 | Washing Machines
The felt gasket came almost all the way off whats the best & easiest way to fix it
You will need to take the whole machine apart and decide whether you wish to reuse to old one or replace it. Remember, a new one will be VERY tight and hard to replace, ( on purpose ). If you old one is in good shape, you will need some super glue to glue it back on. I do not mean the product "super glue". It take a special cement, heatproof.
You may obtain a part number on "Sears Parts" by model number.
You may also find parts on "e-bay".
Be blessed.
Aug 20, 2011 | GE Dryer Repair Video Older Models
How to get into the trap where objects from pants pockets end up
The trap you are referring to would be the drain pump. The following link explains how to access and clean out the drain trap on these pumps:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provied and let me know if you have any questions. I hope this helps you find what you are looking for.
Nov 25, 2009 | Kenmore HE2 Plus Front Load Washer
Lost my diamond wedding ring in washer. Where could it get stuck? My husband took the front off the washer, and opened the drain filter..nothing :( Could it get caught in the hose?
it could get caught in the water pump or between the water pump and hose outlet, it could be caught between the agitator and the washing machine tub or it could be in the **** Trap in the wall, since it's heavier than water it would be the most likely place. and if not there then the over fill tub on the sides.
Jun 13, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool ultimate care II lost item in washer or dryer
Feb 27, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,694 people viewed this question
Dan Webster
Dan Webster
Sal De
