Question about Hisense Televison & Video
Hisense phd4220us no picture
Has sound no picture when turn on tv made a noise
  • 1779 Answers
SOURCE: hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Posted on Feb 27, 2008
  • 13433 Answers
SOURCE: hisense tv
so whats the remote you have there?
Posted on Oct 23, 2008
  • 46 Answers
SOURCE: Hi I have a Hisense
If you are using a dvi cable you will have to run a seperate audio cable to the flat screen tv input.If you are using hdmi cable then change it.If your using the yell,blu.green cable you need to run a seperate audio cable.Be sure you have the connection to aduio in and not plugged into the audio out on your tv.Try also to get a signal over the air tv and see if you have sound then.If you do you have a connection problem.Bty make sure you have the volume turned up( lolq).If all that still fails the tv is defective.Hopes this helps
Posted on Apr 27, 2011
AJIN G
  • 6694 Answers
SOURCE: I have a 22 inch
hi,
Its sounds like the LCD pannel driver ic faulty. In lcd tvs bellow 32 inches this ic is integrated to (part of) the lcd pannel. In 32 inches or above this is a separate circuit board name T-Con board. In your one it is on the pannel itself. There is no repair possible with this. This ics drives the pixels on the LCD screen. To repair the same You have to replace the lcd pannel. The LCD pannel is the most costly part in an LCD tv. Also it will be available only from the authorised servicing center for the Hisense. Its Better to go for a new tv than reparing it.
OK
Posted on Sep 03, 2011
SD Tech
  • 14553 Answers
SOURCE: My Hisense tv power light is blinking. No picture
set is either not getting out of standby or is in shutdown because of a problem inside.
First place to look is the power supply board--follow the power cord inside as it goes right there first.
A quick look will tell you if for example you see puffed up caps what your problem is.
These caps are puffed up and that means bad--if this a fairly inexpensive fix is possible.
If you find this and want to know what to do make a comment here.
Posted on Apr 06, 2012
How do i do factory reset on hisense tv ive gotsound but no picture i tried a hard reset i cant watch movies either
Should have worked after the hard reset. Your problem could be with the leds or the inverter board. Do the flashlight test.
May 06, 2017 | Hisense Televison & Video
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
Jan 13, 2016 | Hisense Refurbished 50"" 1080p LED-LCD...
Bad LED on Hisense 50H5G, no picture or sound, but the Hisense can be seen with flashlight.
Hisense can be unbelievably expensive on parts, consider a salvaged part with a warranty from shop jimmy or similar, much cheaper than the manufacturer but you will have to fit the panel or find a capable friend
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 05, 2016 | Hisense 50 Class LED HDTV - 1080p, 1920x...
I have a 50 inch Hisense TV and the picture went out but I'm still receiving sound.... Can you please help me with a fix for the problem?
It all depends what has led up to the problem, however if there has
been no indication of something going wrong,ie. picture getting dimmer, the most common fix is to reset.
First just check all cables are firmly connected. If that does not work then....
Unplug tv, disconnect from cable box, satellite box, any receivers.
Also turn power off to them as well.
Connect everything back and turn on.
Here is a video of other generic problems that can go wrong on any
tv that leads to sound with no picture.
TV Has Sound But No Picture Troubleshooting Guide
Nov 19, 2015 | Hisense Televison & Video
Hisense 50in hd tv has no picture but has sound
Sounds like either the CCFL tube (like a mini florescent tube) or the inverter that powers it has blown.
Sep 07, 2014 | Hisense LTDN50K360GUS 50" LED TV...
No picture hisense flat screen LCD tv
Sounds like a main board fault. Contact any service technician to make it confirm. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Hisense Brand TV REMOTE EN-31201A for...
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
Hisense TV No picture only Sound
I have the same problem...please assist
May 07, 2010 | Televison & Video
Televison & Video Logo
44 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
