Question about Yamaha Audio Players & Recorders
Have a yamaha natural sound amplifier a A -230 when power on output level goes flat out without playing anything?
When i turn on the output levels go too max without playing anything?
mjap
  • 107 Answers
SOURCE: eltax avr-200 no sound
Eltax AVR-200 will start up in protection mode if the amplifer went into protection mode due to high volume before it was turned OFF and it will start at the same volume level as it had before power OFF.
To correct this you must shift to another input without signal, then turn the volume down before it goes into protection mode again.
Posted on Jan 13, 2008
  • 54 Answers
SOURCE: onkyo 9555 protection circuit
Make shure your speaker wiring is solid hookup to amp and spekers (NO CROSSED WIRING). Also make shure speakers are not wired in parallel or the speaker impeadance will be to low and amp will kick out.Turn speakers off then hook up headphones and crank up volume then see if amp kicks out.If it does you have an internal overload and needs serviced. If it playes ok then you must have speaker problems or wiring.
GOOD LUCK
BIGREDl
Posted on Apr 02, 2008
  • 319 Answers
SOURCE: AMPLIFIER CENTER CHANNEL NOT FUNCTIONING
Center channel will not work unless unit is set for Surround or Pro Logic. Make sure center channel's volume is up
Posted on Apr 29, 2008
Grubhead
  • 5047 Answers
SOURCE: I have a Yamaha natural sound stereo amplifier
Try these for starters!
Is the power switch broke? Check the power cord! Are any internal fuses blown. Look inside for damage/burnt parts. Are the printed boards broken? after say being dropped? Is the transformer working? Check around the power supply area for faults.
Note - be careful your dealing with mains electric!
Posted on Jul 06, 2009
petraman7
  • 1175 Answers
SOURCE: After 10 years of function
I would have the power supply capacitors replaced. After several years ( from heat and age) they dry out and dont put out proper DC voltages to run the amp.
Posted on Oct 12, 2010
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
Can I use this receiver with my 50 watt max speakers?
Yes.
However; there are quite a few factors that are going to effect the performance you'll get with this equipment combination while ensuring you won't damage them. Speaker design type and what you'll be listening to with them are just the basic of basics.
Do not attempt to drive additional bass. It is probably best that you adjust the bass with the tone control to roll it back below input level.
If you hear distortion of any kind, it's too loud.
Dec 26, 2014 | Yamaha HTR-5840 Receiver
Sa-he70 subwoofer no sound
Hi, The sub woofer does have a level control, is this indicating that the level is moving?
Woofers are a power device and usually active, i.e. needing a power amplifier to feed them. If this is a stand alone speaker though try using an AA battery on the wires. you should here a click when you touch a battery on it. If you can see the cone move out then the wire that goes to the + of the battery is the red or positive wire, if not turn the battery around. do not use anything higher that AA i.e.1.5V If you hear a click the speaker is ok and the amplifier is either faulty or not turned up. Tim
Aug 22, 2014 | Panasonic Audio Players & Recorders
Plugged in my old jvc turntable and i can't hear sound coming from the speakers. Any idea what is wrong?
!0 Try if you can and play a record on another amplifier Those were "HiFi" players and the output from the cartridge is max 5/1000 volts which is tiny for aux inputs so you will have to use a pre- amplifier to boost this miniscule output to "Line" levels. Check yourbstilus when was it last replaced?
Aug 20, 2014 | Audio Players & Recorders
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
How do i connect my sonance 275 SE amplifier to my denon receiver
The answer depends on if you have external speaker level volume controls (usually in-wall type) between the amp and the speakers.
If yes, hook the RCA cables from the 275 inputs to the Denon's Tape Output. With speaker level volume controls set to max, use the level controls on the front of the 275 to set max level desired in each room.
If no, then you must use a line level volume control between the Tape Output and the 275.
Jun 22, 2013 | Sonance Audio Players & Recorders
Very low volume on all drums.
I don't think there is anything wrong, it has a very low line level output intentionally. This is to minimize distortion to an amp or mixer. Mine is the same and also a different brand. It is actually made so you could play it through a stereo without damaging it.
Mar 06, 2013 | Alesis DM6 Electronic Drum Set
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
I just bought the t.55 usb turn table and am having trouble playing it. Do you need an amp?
hi,
yes you need an amplifier with or without phono input.
your turntable has three types of output
1.phono output (can connect to the phono input of an amplifier which has a phono input)
2. line level output [can connect to ( aux,cd,tape,tunner what u prefer) an amplifier which has these inputs]
there is a selection switch for phono or line level output on the back side
3. and usb( to computer)
Jan 06, 2011 | Stanton T55 USB Turntable
My PS3 only has audio and no video when I play games and DVDs. This is through a HDMI cable. Am I missing anything?
Check cables again Also setting for tv if set higher then max resolution tv wont display hold power button til system beeps and then shuts off to reset turn system back on with both supplied cable and HDMI connected and go between both settings to adjust HDMI if you have turtle beach headset connected for Sound to go through both tv and headset Audio output must be set to Multi output set to ON headset will be downscaled to Channel 2
Jul 30, 2010 | Sony Playstation 3 (PS3) Console
139 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
