Question about Maytag Washing Machines
I would like to buy a repair manual for model NAV5800AWW washer
    Genius:
  • 1,550 Answers
You can get from the link below
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177162
Posted on Jan 03, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a repair manual may be purchased from here.
Alternately, exploded parts diagrams and a wiring diagram as well as parts description are available free from here.
Good luck and Thank you for using FixYa.
  • 13,433 Answers
  • Maytag Master
  • 19,396 Answers
I think that you can find the service manual here: http://www.servicematters.com/maytag_library/docs/16022937.pdf
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Previous post on a Kenmore washer
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Jan 31, 2009 | Washing Machines
Washer won't run
Well this means your motor is fried.
if it is more than 8 years old it is not worth putting good money into it. time to replace.
Repair or replace?
Dec 05, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Water leaking between drum and top of gear box.....Washer is an Amanda NAV5800aww
center seal leaking ..repair not for faint of heart if you hire it done be sure they change upper bearing ..water is leaking onto bearing and failure can occur in less than 2 weeks after seal replacement
Oct 03, 2008 | Amana Washing Machines
1997 maytag front load washer has smell of burning rubber in the chamber.
You said, after we did a wash, strong smell of rubber inside the wash chamber once it was opened...do we get a repair estimate or should we consider replacement at this point...who to call? a maytag repair place or any appliance repair shop?
How old is the model?
It may be only the belt is worn and or slipping.
If you need to repair ,our site has some good repair companies that are our sponsors.
Off to the right of the screen in our site is a window that you can type your zip code into and they
will find you service near you home.
Here is a report I just read that may help you evaluate fixing or buying new!
Repair or replace?
Note that washer is under warranty might require service from a factory-authorized technician;
given that today's models are quieter and have added features.
Data also shows that it doesn't pay to fix a less-expensive washers.
of a washer you replace is likely to end up in a landfill.
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer vibrates on spin cycle and is falling apart,
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You say, your door is cracked.soap dispenser is cracked and falling apart?
How old is the washer????????????
Waiting for your response!
Repair or replace?
Thank You, HUUUM
Aug 27, 2008 | EuroTech EWC177 Front Load Washer / Dryer
AGITATOR
You are missing the coupling that holds the agitator to the shaft.
Aug 24, 2008 | Amana NAV5800A Top Load Washer
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
May 14, 2008 | Amana NAV5800A Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
