Question about Watches
Cannot set time and date on my Roots athletic watch RY2211 even after following instructions
Can't get date to change
4 Suggested Answers
SOURCE: CAN'T SET TIME
I have an AW 150 watch. I looked everywhere for a solution to setting it. I found nothing. It appears that all types of this watch are hard to set. I happened upon the correct procedure for at least setting the watch.
My watch has 4 set buttons that you can push. 2 on each side. Hold the upper right hand button until something starts flashing on the watch. On mine it was the seconds. Then release the button. Now each time you push that button for a very short moment, the flashing part of the watch will progress through each area (minutes, hours, date, etc). When you get to the area you want to set/adjust, use the bottom right hand button to move up/forwards and the bottom left hand button to move down/backwards. When you have fixed one function push the upper right hand button to move to the next function you want to change and repeat the procedure. When you are done, hold the upper right hand button in until the watch quits flashing anywhere and then release the button. Your watch is no longer in the adjust mode. Hope this works for you. It drove me nuts until I figured it out.
Posted on Mar 09, 2009
SOURCE: Athletic Works Watch
With time displayed:
Press lower right, then upper left.
Posted on Nov 25, 2009
SOURCE: How do you set the time on the Roots Womens's Mai
you can find the instructions on the manual at this website http://www.watchroots.com/athletic_manual/athle-index_eng.html
Posted on Aug 13, 2010
How to change time on roots watch ry2203
Press and hold "MODE". Press MODE 2 times (after the first time, the alarm time flashes, after the 2nd time, the second flashes). Press ADJ to change seconds. Press ST/STP to switch from seconds to minute. Press ADJ to change minutes. Then press ADJ to change hours. Press MODE when done.
Apr 06, 2013 | ROOTS Athletics Wrist WATCH Water...
How do I set the date on my Roots MAI TAI RY2142 Watch for Women?
Start by holding in the mode button (bottom left) until the first number blinks, then let go. You are actually in the alarm mode right now, now press and release the mode button and enter the time setting mode, the seconds will be flashing. Now press and release the start/stop button (top right) and the minutes will flash, again for hours, again for the month, and again for the date. When the parameter you want to adjust is flashing just press the adjust button (top left) to change the numbers. When your finished simply press the mode button to exit the setting menu. Worked for me, hope it does for you too. Most of the other setting changes are tricky as well, just ask for help again if you want to change the alarm or 12 or 24 hour clock etc....
Jan 03, 2013 | ROOTS MAI TAI Ry2142BLK Watch
Guess Athletic--date is one day ahead-want to set one date back (5-9)
Hi, you have two options to do this:
  1. If you have a spare watch, pull the crown (winder) out to the full time adjust position. Check that the watch has stopped and leave it for 24 hours then adjust time and push crown back in again to restart the watch
  2. You will need to wind the date on through it's full 31 day cycle, as 99.9% of date display watches can only go forward, not backwards.
Hope this helps :)
May 10, 2011 | Watches
I can't set the time on the Timex 1440
To set the time on your Timex 1440 Watch, please follow these directions:
1. Press and hold MODE (Upper left button)
(HOURS will flash and you'll be in Alarm Mode).
2. Press MODE again to enter TIME mode.
(SECONDS digits will flash.)
3. Press ADJUST (bottom right button) to set SECONDS to zero.
4. Press START/STOP (upper right button) to select MINUTES
5. Press ADJUST to change
6. Repeat to set Hours, Date, Month, and Day of the week.
(Go through 12 hours to set AM or PM)
7. Press MODE when finished
8. To display DATE from TIME display, press START/STOP
9. With DATE displayed, press and hold START/STOP, then press ADJUST to change display between DATE-MONTH
10. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12 and 24 hour format.
I hope you are now able to set the time on your watch! If you appreciate these instructions, please remember to rate this post.
--Sandy
Apr 18, 2011 | Timex Watches
How do I change the time and date on a roots WR50M?
If you look at the buttons on the sides of the face. One of them should be Set, press that button. Get the "Set" mode, and it will allow you to change hours,minutes, seconds, or date (if available). Press each until you find one that makes one part of your display flash.
The other buttons set the item chosen, usually scrolling upward.
Feb 18, 2010 | Watches
Feb 05, 2010 | Watches
Change day but not date on Timex Expedition
HI..
HERE IS STEPS FOR SETTING OF YOUR WATCH... STEP3 EXPLAINS THE SETTING OF DAY,DATE.....
  • Step 1 Push in the lower right button until you see the seconds flash. Press the upper right button to run the seconds display down to zero. Push the bottom left button to get into the mode to set the hours. Press the top right button to scroll through the numbers. Watch that you choose a.m. or p.m. correctly.
  • Step 2 Press the bottom left button to get into the mode to set the minutes. Again, push the top right button to scroll through the numbers until you reach the correct time.
  • Step 3 Repeat the process from Step 2 four times to set the month, date and day of the week and to change to military time if you wish. Push the bottom right button to save your settings. You'll notice the colon between the numbers will start to flash.
  • THANK YOU
  • Jul 28, 2009 | Timex Expedition Outdoor Athletics Watch...
    How to set the time on Athletic Works watch
    Press and hold the lap/reset button for at least 5 full seconds. You should see the word "SET" appear in the dispaly. Push the Mode button to change from alarm to date to month, time, etc.. Use the start/stop button to change the numbers.
    Jul 13, 2009 | Watches
    Need manual/User Guide for an ''Athletic Works'' watch, model V403
    Dave,
    If you hold the reset button you will see the number 12 flashing with an H next to it this is for standard or military time. To change it press the st/stp button. To go forward press mode.Then it will ask for the year set that then press mode.Now the date change it just like the Hour and year.then day do the same.Now timeSet that the same and it should work!
    Apr 26, 2009 | Watches
    Mar 12, 2009 | Oakley GMT OAK0531 Wrist Watch
    Watches Logo
    311 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
