Question about Siemens HANDSET GIGASET C59H BLACK 1Line Cordless Phone
Siemens GIGASET C59H HANDSET works on speaker only
When ringing a number the handset works normally through the earpiece but as soon as the call is answered the earpiece goes off and the call must be switched to speaker to hear the other party. Two other phones on the base work fine so it is not the base but that particular hone. resetting the handset has not helped. Any other ideas?
SOURCE: Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Posted on Jan 06, 2008
  • 518 Answers
SOURCE: siemens gigaset 4215
Then the base is bad. I have 1 base like that also... nothing can be done other than send it out to be rebuilt.
Sorry,
Geno
Posted on Mar 22, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
SOURCE: Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
Posted on Mar 06, 2010
  • 4 Answers
SOURCE: Hi there, I have the Siemens Gigaset 4015 and for
No dial tone for me either. Don't have the flashing problem though. just no dial tone. Tried everything. Let me know if anything worked for you.
Posted on Jan 27, 2011
How do I increase the number of times the phone rings?
I don't think u can, after 25 rings it usually goes to answer phone automatically, if its going to answer phone b4 that then turn answer phone off the automatic setting.
Apr 04, 2015 | Siemens S79H Gigaset Expansion Handset for...
Gigaset A490 speakphone not working
Does the SPEAKER button light up red when you press it?
Does it work on one handset but not the other? Or does it not work on any handset?
It's a relatively common problem with these phones. It's more than likely broken...
http://gigaset.com/medias/sys_master/A31008-M2200-R301-5-3S19_en_US_CA.pdf
Dec 12, 2012 | Siemens Gigaset A490 Twin Cordless Phone
Gigaset a495 showing Register HS, and i cant making call.. plz give me a solution
gigaser A495 Handset ,
Actualy one problem may Handset Disply not work,Pls reply how to work in incoming and disply screen number.
Aug 18, 2012 | Siemens Gigaset A495 Cordless Phone
How do you reset the base and handset of a Siemens 4215 to "0000" ?
My Siemens Gigaset AS15 Cordless Phone is constantly calling the same number, no matter which number I dial! What shuld I do?
Thank you.
Jan 31, 2010 | Siemens Gigaset 4215 Cordless Phone
Handset won't work
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Siemens Gigaset 4000 No Sound
Hi Krister,
It sounds from your symptoms (no pun intended) that your handset receiver/speaker has gone bad, or if you use a headset, the circuit might have gotten ripped open from tension from the headset plug. You can try plugging in a standard 2.5 mm plug headset into it (real common headset). My guess is that you will be able to hear dialtone using a headset and use the phone, but the phone will continue not ring or make key beeps.
Its fixable, but with the Siemens models don't let anyone try to open it. To work properly it needs to snap together tight, and guaranteed they will gouge the plastic and break the more than 10 tabs that keep it held snug together, there are no screws. The skill to open them without damaging them is proper training and muscle memory, which is reserved for the people that do it daily, plus if the plastic needs replacing it will add to your costs. Nevertheless, if you want it fixed, just google "Siemens Cordless Repair" and click the first or second non sponsored link to make arrangements to get it fixed. Good Luck and let me know if I was right about the headset audio.
Dec 15, 2007 | Siemens Gigaset 4000 Phone
Siemens HANDSET GIGASET C59H BLACK 1Line Cordless Phone Logo
124 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
