Question about LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White
LG Sense Clean DD error code "FE" front loader washer/dryer combo
Error flashing "FE" don't know what it means.
  • Anonymous Mar 15, 2014
    Samsung vrt front loader washer
My lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Posted on May 28, 2009
WHAT DOES A UPSIDE DOWN FE CODE MEAN ON A WM2277HB LG WASHER FRONT LOADER
I think it is actually a 'tE" error code. Thermistor error. Pretty easy fix. And under $10 part. Repair videos exist on YouTube, repairclinic.com or appliancepartspros.com. I would suggest that you look at videos and see how they all suggest you do the repair. Top off, control panel off, front off. Fairly complicated but very doable. If you get the part and study the parts diagrams, you can do the part replacement by turning washer on its side and do replacement from underneath. Takes a little feeling around but much easier.
Feb 16, 2017 | LG Washing Machines
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
Error code upside down FE
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. You can search for the meaning of
the error code on the site.Don't worry about the
timer, they hardly ever go bad.Good luck with it.
If I have helped you, please rate my advice on fixya.
Nov 27, 2009 | LG WM-2277HW Front Load Washer
LG Washer/Dryer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Samsung WD-J1255 Front loader Washer/dryer combo
I have a similar problem with the FE Code. All i have manage to ascertain is that if you set the spin at 400 it will complete the cycle
Nov 01, 2008 | Washing Machines
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Fe MEANING
It typically means that one of the water valves (that opens and closes to let the appropriate amount of water into the machine) is not functioning properly. It is frequently accompanied by a continuous flow of water into the machine (although with the drain pump also running you won't necessarily see any water building up inside the drum.) I believe the letters actually stand for "Fill Error."
Mar 17, 2008 | LG WD-3274RHD Front Load Washer / Dryer
LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Sep 12, 2007 | LG WM2688H Front Load Washer
LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer - White Logo
3,244 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
