Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
What is the dwell angle on a briggs and stratton 17.5 hp motor ?
3 Suggested Answers
eugbug
  • 479 Answers
SOURCE: briggs and stratton 5 hp engine won't start
An engine not starting can have many causes but it is usually due to lack of fuel being sucked into the engine or no spark.
Remove spark plug. It should be damp, if it is wet, the engine has been flooded and should be left for a few minutes for the fuel to evaporate. Replace lead on the plug and hold the threaded part against the engine somehow. Make sure you don't hold the lead in your hand!
Pull start the engine and ensure there is a spark.
Posted on Jun 21, 2010
  • 24 Answers
SOURCE: I need a wiring diagram
This wiring diagram is from a 15HP but it should be the same as your engine.
Posted on Jul 12, 2011
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Briggs & Stratton 16.5 Motor workshop manual
go google and type in-- workshop manual for briggs and stratton 16.5 hp motor -- if there is a pdf version , down load it
remember that the manual will cover a range of hp motors so a manual may be 14-20 hp
Nov 03, 2016 | Briggs & Stratton Measuring Tools &...
How to remove piston from 17hp Briggs & Stratton mower engine?
You take the head off, remove the crank case cover, take the bolt off the piston journal on the crank shaft, push the piston out of the top of the engine. To get it back in you are going to need a ring compressor and should use plasti-guage to check clearance on the crank
Oct 13, 2015 | Briggs & Stratton Measuring Tools &...
How do I remove the horizontal shaft
the motor you are working on has a split block and you have to take the motor off and remove the bolts holding the two halves of the block apart. this motor doesn't have a separate removable head. it is cast as two pieces and in my opinion makes more work for some repairs. hope this helps
Oct 13, 2015 | Briggs AND Stratton Intek Briggs &...
13 HP briggs and stratton intek motor on a pull behind weekend warrior brush cutter
Manuals - Briggs & Stratton
https://www.briggsandstratton.com/us/en/.../manuals
Briggs & StrattonFind Briggs & Stratton manuals online by selecting your lawn mower or product type &engine model number. Never worry about losing an owners manual ...
Sep 10, 2015 | Measuring Tools & Sensors
Tightening sequence for briggs and stratton 17.5 hp engine
tighten bolts opisite of each other snug then one 1/4 turn to tork
Oct 06, 2014 | Briggs AND Stratton Intek Briggs &...
Briggs service manual 311777
Try Partstree.com in Austin, Tx. They seem to have just about everything.
Jul 20, 2014 | Briggs AND Stratton Intek Briggs &...
Which valve is the intake valve on a 17 hp briggs engine?
look at the valve s one is smaller than the other one this is the intake the big one is the exhaust valve
Jun 11, 2014 | Briggs AND Stratton Intek Briggs &...
B&S 17 hp single it only turns over til it hits compression.. good battery,starter turns over another motor ,ground wire,whats up!
The connections on the starter solenoid coil are poor. this is the two smaller wires on the solenoid but all of the wires should be removed and cleaned well at least once a year or more often if conditions warrant.
Jun 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
136 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
