Question about DeLonghi Microwave Ovens
Delonghi EM821AAN TURNTABLE NOT WORKING
MODEL EM821AAN
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: DeLonghi microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 09, 2009
  • 2841 Answers
SOURCE: Delonghi EM821AAN-800watt The turn table has
Make sure the turntable guide is lined up properly and there is no debris caught in it. Examine the turn table bushing the tray sits on and make sure it is not worn or broken. Make sure the turntable is sitting down in the groove correctly. Lastly it may be the drive motor itself is bad. This is the small motor that turns the carousel. This motor is very difficult to replace and unless you are qualified you should not attempt this repair and leave it to a professional. This motor will cost from $40 to $75 plus the cost of having it replaced. You may want to consider buying a new microwave if this unit is over 5 years old. You could end up spending more to repair this one than a new one costs. Of course you can use it without the carousel.
Posted on Dec 02, 2009
sonicboomele
  • 1557 Answers
SOURCE: my delonghi em821aan-x2 works without making food
in most cases the magnatron has gone bad as they are very expensive in most cases we write them off . sorry i think its time for a new microwave
best wishes
sonic boom electronics
Posted on Nov 06, 2010
Microwave making noise all the time if plugged in & door shut
Sounds like a bad control board. Change it or buy another unit.
Jan 21, 2013 | DeLonghi Microwave Ovens
My delonghi em821aan-x2 works without making food hot
best wishes
Nov 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Delonghi EM821AAN-800watt The turn table has stopped spinning
Dec 02, 2009 | DeLonghi MW 605 Convection/Microwave Oven
The glass plate will not rotate when trying to heat up your food...
Sounds like either the turntable motor has seized or that the shaft of the turntable motor has broken off inside the roller ring. You may need to chek with your local De'Longhi repairer.
Nov 29, 2009 | DeLonghi Microwave Ovens
Where can I buy a turntable motor for a Delonghi AC925EQK microwave. The motor is a Hengxing TYJ50-8A7 220-240v 4W 4RPM
Don't know if you got your motor or not, but I've just ordered an identical part number from ebay - search for "microwave turnable motor".
It is advertised as a Panasonic part but has the exact part number you want.
Jun 21, 2009 | DeLonghi Microwave Ovens
My Delonghi mcrowave turntable is not turning.Please can you help?Thanks
Thank you for your eMail.The problem seems to sort itself out through luck more than anything else!I have made a note of your address for future reference.Thanks again.
May 12, 2009 | DeLonghi Microwave Ovens
Jan 07, 2009 | Microwave Ovens
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Lisa
Lisa
tfelton3
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
