Question about Whirlpool LEQ8000JQ Electric Dryer
Scraping noise with burning smell
When the dryer is on, I have a metallic scraping noise accompanied by a burning smell. The tumbler rotates fine. I am currently trying to get the blower wheel off to see if something is stuck in the belt or motor. I am not able to get the wheel off, any suggestions?
  • 1 more comment
  • pacowahoo Jan 04, 2009
    I have already tried that. The sound is coming from behind the blower wheel.
    It is a whirlpool ultimate care heavy duty super capacity plus. I cannot find the model number on it anywhere.
  • pacowahoo Jan 05, 2009
    It is a solid hub fan, there unfortunately is not a nut on the outside of the fan. It is also a green color. What the directions on the back of the lint blower tell me, is to hold the blower motor shaft and turn fan clockwise. The motor shaft is very hard to get to, but I am able to hold it with a crescent wrench, but the fan blade still does not come off.
    President:
  • 2,976 Answers
You quite possibly have something like a penny or a paper clip stuck at the heat duct. ***First-shut off the electric to the dryer***. From behind the dryer, remove the heat tunnel and clean it out. You will be surprised how much lint gets past the filter. It's an easy repair, just a few screws. While you're back there, look around for any buildup in other areas.
Posted on Jan 03, 2009
  • 1 more comment
  • David Shaub Jan 04, 2009
    I need to know the make & model of the dryer. They're all a little bit different.
    There should just be one bolt or screw in the center of the fan. You'll have to hold the blade from turning to remove it. The screw might be reverse thread. If the fan blade is white, it is press on. It is also a discontinued item, so be careful.
  • David Shaub Jan 05, 2009
    If you have a small pair of needle nose pliers, you might be able to open them up the whole way and span the fins. This will give you more of a grip. Since it tells you to turn clockwise, it has reverse threads. Make sure you're not trying to turn it counter clockwise out of habit.
Why is it making noise and smelling like something burning?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Mar 07, 2015 | EuroTech EDV158 Electric Dryer
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The belt loose or worn can make funny noises
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
Tumbler not rotating, metal on metal smell
Bad idler or roller? Broken belt? Open it up and take a look see. Here's HOW
May 21, 2010 | Kenmore 67632 Electric Dryer
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
My dryer is making a loud squeaking noise when it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 27, 2009 | Dryers
Dryer was making some high pitched squealing sounds, not it thumps with each rotation. Whatdo you thin it it?
Sep 13, 2009 | Dryers
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer making squeeking noise
Check the dryer belt tensioner and pulley assembly. It be wearing out. You'll need to remove the back cover of the dryer to do this. Turn off the gas and/or electric before working on the unit.
Mar 26, 2009 | Maytag MDE9316 Dryer
Scraping noise
hi there,
the scraping could be the tumbler itself. please check the belt around the tumber and make sure that it's not worn.
thanks
Sep 29, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
176 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
