Question about Faema Emblema
Faema emblame user manual
I did lost my machine's user manual. So, i need a how can i control the hot water temperature on programming. Please talk to me..
5 Suggested Answers
SOURCE: User Manual
Please email me tomorrow at dspringer5114@hotmail.com. I can scan my manual and send you the pdf from my office. I just need you to remind me. Thanks
dgsrgr8
Posted on Jun 01, 2008
EsWorld
  • 1618 Answers
SOURCE: User Manual for Faema D92/A, doesn't dispense coffee, only water
This will take some time so bear with me.
The problem with the machine is most likely the solenoid valve(black or blue electrical box connected on the side of the group), for easier access remove the front panel there are about 5 screws holding it in place, 2 on the bottom and 3 on the top under-side. Disconnect or turn off the water supply. Then using a 14mm open end wrench remove the nut and the discharge pipe. Do Not remove the 4 small allen wrench screws on the brass piece connected to the machine. Now remove the electrical box over the silver pipe, and using a cressent remove the silver pipe from the brass rectangle square. Slowly open the water supply, if water shoots out then the head is clear, we will move on if not, use a pin and clean the middle hole. Check the silver pipe also there is a small plunger in there press it in if it moves freely then we are good, if not you can try soaking it in puro caff until it clears or just get a new solenoid coil. Remove the shower screen and screw in the group head, you can soak those also.
If you still cannot get water, then we will have to go deeper into the machine.
Posted on Jun 03, 2009
  • 3 Answers
SOURCE: Commercial Faema Espresso Machine with 2 heads, model #E97/A-2
I need the E97 faema Manula the A3, I think it is the same as the A2, I appreciate it if you have it and sent it to my mail. Thanks gbproduc@hotmail.com
Posted on Dec 01, 2009
  • 91 Answers
SOURCE: I have a Faema commercial espresso machine model
Pdfdatabase.com. Put in Faema D92 and you can download the service manual.
Posted on Feb 17, 2011
Our coffee machine is continually beeping and the water flow will not flow automatically, is there a reset button or something
It's beeping because it's in programming mode. Usual reason with a machine of this age is that the touchpad has failed. Water gets into the touchpad membrane after a while, which makes the controller think a button has been pressed. If it thinks the STOP button is being pressed/held for more than 5 seconds, it goes into programming....
To confirm: Remove drip tray, take lid off controller box and unplug one of the flat plugs from the keypad (there will be two long thin plugs next to each other, and probably a space or two for extra plugs). When you get the correct one, the beeping will stop and the machine will resume normal operation on the working keypad.
Oct 23, 2014 | Faema Smart A2 Automatic Espresso Machine...
Faema smart a2 espresso machine i need to reprogram it is there any one can help me out
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
Jun 06, 2014 | Faema Smart A2 Automatic Espresso Machine...
Faema e92
There is an economizer valve on the machine that needs to be adjusted. I will assume it was pumping hot water, this is not a new installed machine, then the machine has scale buildup that is preventing the hot water from leaving the boiler through the tubes to the solenoid, only the mixed cold water is being dispensed. If this is a new installed machine, adjust the economizer on the boiler, remove the left panel for access. Big nut on the boiler you will see where it connects to the solenoid.
Dec 16, 2013 | Faema Coffee Makers & Espresso Machines
Hot water fills with hot and cold not strictly hot what is the fix
see the causes: and proceed with common sense. God bless you
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on. Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct. Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the
Sep 22, 2012 | Roper Washing Machines
Need a users manual in english for the faema due espresso machine
Try Googling (faema)(FA60081)(manual) without parens. You may have to refine your search to get an English version.
Oct 10, 2011 | Faema FA60081
Bought a used Faema Eurostar Combi. Don't have a
If it's the same as the used one I just picked up, there is a dial position for coffee, with a little cup on it. The dial position for steam is the one that cares about the positoin of the steam/hot water button.
The coffee position will never use steam and you don't need worry about the position of the steam button if you're not frothing milk.
Jun 29, 2010 | Faema FA60081
We have a faema e92 but our mains water is off, can we manually fill the tank without mains water?
The machine can sack the water directly from a water tank since the water inlet hose is conected first to presure pump. Just insert the water inlet hose in a water tank, however please take care that if you leave the pump work without ay water for more than 2 minutes the pump might be destroed.
Feb 13, 2010 | Faema FA60081
It can be many things. If I understand machine start working (pouring water) itself, otherwise not working.
Probably your touch pads is bad, must be replaced. If I now more about problem mighty I can help more.
Mar 14, 2009 | Faema FA60081
User Manual
dgsrgr8
May 31, 2008 | Faema Coffee Makers & Espresso Machines
Faema Emblema Logo
61 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
pawnpower
richie46
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
