My husband put pods in our detergent drawer of our front load whirlpool washer. Now it has a F21 code. I have to out it on drain and spin to get thw clothes apun out. HELP how do i fix this? Obviously theres a build up of pods somewhere in the machine. Also after each use the drawer has water in it.HELP!!!!
5 Suggested Answers
SOURCE: Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Posted on Aug 17, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore front load washer won't drain
Remove the bottom panel under the door to access the drain pump. Make sure the washer is unplugged before servicing the pump. The pump will be located under the wash tub in the front of the washer. There should be a small access cover that can be unscrewed to access the inside of the pump. If not, remove the inlet hose to access the pump impeller. HINT: Pull the drain hose from the standpipe and use a shop vac to pull a vacuum on the drain line. This will pull any remaining water out of the drain lines and wash tub. This will minimize the amount of water that spills out of the drain pump when you remove the access cover.
It does not take much to damage this small drain pumps. If you clean the pump thoroughly and it still exhibits drain problems, the manufacturer recommends replacing the pump.
If you require additional assistance, let me know before you rate the solution. I hope this helps you.
Posted on Feb 02, 2009
SOURCE: front loading washer won't spin
my amana washer wont spin and does not drain
Posted on Sep 12, 2009
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
Tip
Whirlpool duet washer F02 or F21 error code.
This error code indicates that drain times are longer than expected.
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Temporary fixes:
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
on Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin or drains shows F21
The F21 error on a Whirlpool Duet washer means the unit was draining slowly. This can be caused by a blocked outlet hose (kinked hose, for example), excessive suds from using non-HE detergent or too much detergent, blockages in the drain pump filter (coin catcher), or a problem with the pump.
You should be able to clear the error by pressing Pause/Cancel twice. Check your outlet hose. Then unplug the washer. Have a bucket handy to catch the water when you access the pump. Remove the toe panel from the bottom of the washer. There are three screws to remove; then you need to lift the panel slightly and pull it forward.Check the filter for foreign objects.
Test the washer by selecting a cycle and running it with no clothing or detergent. If the unit still fails, then the pump, pump motor or the pressure switch is bad. However, you should also check the wiring to the unit.
I hope this helps. Please add a comment with the model of your washer for specific directions and parts information.
Dec 22, 2014 | Whirlpool duet Washing Machines
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
THW WASHER IS NOT DRAINING PROPERLY
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer stopped and was flashing F21 (drainage issue) so I called a plumber. He checked the hoses and removed the panel and cleaned the drain trap. It didn't fix the problem it's still won't drain. It...
The SUD message relates to overdose of detergent detected during the Wash Cycle.
This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds.
If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked. this seems to be the reason as to why your unit is not fixed even after trying to solve F21......
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Good luck
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Waher machine stops before rinse
Using the wrong detergent may or may not have had something to do with this error. It is important that you use HE detergent in these washers, though. If you don't, you are in affect adding a higher concentration of detergent in a washer that only uses 5 to 7 gallons of water. Regular detergent is formulated for a wash tub with a 35 gallon capacity. Using it in an HE washer can cause excessive sudsing, premature failure of the drain pump and seals, and annoying error codes.
First, try running a DRAIN/SPIN cycle to clear out any excessive suds. You may have to repeat this process several times. Next, leave the washer unplugged for 30 minutes to see if the Central Control Unit (CCU) will reset and clear the error codes. If the problem continues after a CCU reset check the following:
Check your drain pump for obstructions. The "F21 error is a Long Drain error code. If there's something obstructing the drain pump, the washer will not complete the wash cycle. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Also check the drain pump connector plug to ensure it is not loose. If cleaning the pump does not correct the error, you may have a pump that no longer pumps at the correct volume. If this is the case, you need to replace your drain pump.
The "F27" error code is an Overflow Condition. It can have several causes, but the drain pump is the common link with these two error codes. This error can be generated if air is detected in the drain pump (suds), or if the pump is not working.
If you have questions, please let me know. I hope you find this information helpful.
Jul 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F21 on Whirlpool front load duet washer
"F21" is a Long Drain error code. The following link explains:
In most cases this is simply caused by a clogged drain pump and all that is required is a good cleaning. Read through the instructions provided in the link on how to do this. Make sure the washer is unplugged while servicing any of the internal components.
If the problem persists, you may have a drain pump that is malfunctioning or is damaged. The manufacturer recommends replacing the pump if this is the case.
Let me know if you have any questions. I hope this helps you.
Jun 12, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
