No read record or play
Vhs side records and plays ok
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
A combo unit with DVD and VCR---if the DVD WILL not read the disc etc it is almost always with this type of unit a dirty or bad optical pickup in that unit.
Posted on Oct 30, 2012
pseudonym
  • 15 Answers
SOURCE: Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Posted on Sep 18, 2007
jerryg50
  • 1689 Answers
SOURCE: will not record or play back VHS for more than 30 seconds
I can tell you some ideas genericaly for VCR's.
This could be an idler wheel assembly problem, or a tape tension, or a reel torque problem.
It can also be a power supply problem where the supply is working just on the edge. Due to some worn components in the supply it can be partialy shutting down.
Your machine will have to be checked out by an experienced VCR tech.
Jerry G.
Posted on Dec 04, 2008
SOURCE: dubbing VHS to DVD
You have to go into the Home menu and select setup. At the bottom left there should be an icon that looks like a dvd disc. Select that and then go to finalize and select that to finalize the disc. After that is complete it should play on any dvd player. I had this problem and I got through to LG's customer service line and had them talk me through it. After I finalized the disc, it worked.
Posted on Feb 05, 2009
SOURCE: panasonic dmr-es45v
The disc drive motor is burned out, its junk...if you didn't finalize the discs, they're junk too unless you buy another Panasonic DMR.
Posted on Feb 10, 2009
nandosnut
  • 112 Answers
SOURCE: panasonic dvd recorder wont record or play
It is also possible that you are trying to record using an already used -R or an unformatted RAM disk.
Posted on Apr 20, 2009
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
VHS to DVD recording
OK connect the AV Out Yellow, Red, White, OR SVHS, OR SCART, from the VCR, connect these leads color to color to the DVD's AV whatever, IN.. Press Play on VCR, and "Record" on CVD that should do it.
Jan 31, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic dvd recorder wont record or play
Mar 07, 2009 | Panasonic DMR-E55 DVD Recorder
I've purchased a philips dvd videoplayer, dvp3350v/05, with the aim of being able to copy from video to dvd...having read the manual though, it reads like the only copying it will do is from dvd to...
The DVP3350V/05 is a DVD player / Video recorder combi, so will only play DVDs, not record on to them.
You will need a Philips DVDR3510V or DVDR3512V, to record from VHS to DVD.
www.cheapestelectrical.co.uk should have them in stock, if not contact them for availability.
Also, most pre-recorded VHS tapes are copy protected, so you may experience picture rolling and colour fading in & out on any copies you make.
Any VHS tapes you have recorded yourself will not have this copy protection, and will copy ok.
Jun 04, 2008 | Philips Televison & Video
New Unit- Plays VHS - Records VHS - Plays C.D's - but ... ALL DVD's say
How old is your player?, has it ever played DVD's ?.
Try and avoid cleaning disc's.
Dec 04, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
