Question about ASUS P5KPL-AM - Motherboard - micro ATX - iG31 - LGA775 Socket - UDMA133, Serial ATA-300 - Ethernet ... (P5QPL-AM)
Dma-1 error fatal error system halted : this message is displayed when I try to boot my new asus p5qpl-am motherboard. Can anyone help me PLEASE
  • 177 Answers
SOURCE: Error Boot "Chasis Intruded fatal Error System Halted"
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
Posted on Nov 26, 2008
  • 31 Answers
SOURCE: Chassis Intruded, Fatal Error.....System Halted
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because: - chassis open (close it), - switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you). As another workaround, you can probably disable this switch in BIOS.
Posted on Mar 20, 2009
  • 149 Answers
SOURCE: Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
leecom72
  • 4806 Answers
SOURCE: ASUS p4 intel motherboard giving chassis intruded.
Hi there.
Start the PC and enter the bios using either the Esc or Del key, once in the bios set the chassis intrusion to "disabled" save the changes and exit the bios, the computer will now restart and you should be able to boot into the operating system no problem.
Good luck and thanks for using FixYa!!
Posted on May 01, 2009
hari007_in
  • 138 Answers
SOURCE: chassis intruded ? fatal error... system halted
first you have to check the RAM,, then mother board or processor,, ,,, make sure the pc while booting memory check is going with out problem..s
Posted on Sep 29, 2009
Fatal Error, Chasis Entruded, System halted appear at first time boot up. and if I again restart, sometime it works continuously till I shut down the PC and if I boot up again some times it works or some...
Good day try to remove the memory card, sound card and video card, clean the copper leads using an eraser and try to check all the connectors specially the hard disc, do this and it will resolve the problem, best regards.
Aug 19, 2011 | ASUS P5PE-VM Motherboard
Asus P5RD-2-UM acpi bios revision 0811. Press del to run setup Press F8 for BBS popup initializing usb controllers..done. 992mb =32 mb shared memory avto detecting pri master ide hard disk pri master...
no keyboard detected. fatal error... system halted = your keyboard is dead, replace it. If you get the same message after a new keyboard then the PS2 connector is dead, you will have to use an USB keyboard.
Dec 20, 2010 | ASUS P5RD2-VM Motherboard
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
Dec 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intruded ? fatal error... system halted in asus p5sd2-vm mother board
Sep 29, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Chassis intrusion
You need to check the chassis intrusion pin setting located on the motherboard. See page 1-30 (Number 11) in your manual.
You need to add a jumper as shown.
The system should no longer halt.
Cheers!
Mike
May 04, 2009 | ASUS P5V800-MX Motherboard
ASUS P5VD2-VM SE MOTHERBOARD
If you purchased this motherboard recently then i would double check your power supply - get a better power supply and try that - think you may need one with two 12 volt rails.
If that does not work then I would get it RMA'd as in return it and get a replacement.
Apr 10, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
ASUS P5KPL-AM - Motherboard - micro ATX - iG31 - LGA775 Socket - UDMA133, Serial ATA-300 - Ethernet ... (P5QPL-AM) Logo
2,161 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
