Question about HP DesignJet 430 InkJet Printer
Align roll feed paper
I AM HAVING PROBLEMS ALIGN PAPER IN MY ROLL FEED. IT IS NOT TAKING THE PAPERS AS YOU TRY TO ALIGN. I WOULD LIKE TO DOWNLOAD A OWNERS MANUAL.
    Genius:
  • 2,985 Answers
Http://www.fixya.com/support/p378733-hp_designjet_430_inkjet_printer http://www.fixya.com/support/p378733-hp_designjet_430_inkjet_printer/solutions Check also the HP web site tech help.
Posted on May 17, 2007
SOURCE:
I have an old Sharp EL-1701C calculator and for some reason can not feed a new roll of paper into the unit? Batteries are new and the feed option works well, just doesn't grab the paper roll to start?
you may need to cut the corners off a little bit on the start of the new roll and feed the paper in while advancing with the calculator advance control/button
Dec 10, 2014 | Sharp EL-1701C Calculator
Unable to print - mangles paper
Hi
Try turning the printer off and on.
Check through the paper paths and remove any stuck papers.
Avoid filling the paper feed tray to capacity.
Make sure the paper you're using is the correct type and size for your printer.
Align the paper correctly on the feed tray.
Feb 27, 2012 | Office Equipment & Supplies
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Put new roll in printer and paper feeds through then goes back out again
    The printer should accept print paper ready for feed commands when computer sends jobs with clicks. A paper feeder tray may be clogged, attempt to open compartments to ascertain for misaligned or adjusted entrapment areas. Paper feeder adjustments that are tightened least allows feeder processing while loosened paper feeder clips allows several print papers at a time. Select the appropriate adjustment for the papers. Second, printers that run out of ink display sensitive malfunctions either as inability to feed paper when available. Ascertain that printer ink is available.
    Jan 28, 2011 | HP PhotoSmart 130 InkJet Printer
    How do I install adding machine paper roll
    Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
    If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
    If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
    Nov 23, 2009 | Canon P1-DHV Calculator
    Need help replacing the paper roll on a Casio BIG 12-Digit adding machine.
    Aug 21, 2009 | Office Equipment & Supplies
    Putting new paper roll in
    It's difficult to see, but the feeder for the paper is on the back of the machine, just below where the roll of paper goes. You'll see a little slot above the opening for the batteries. Feed the paper in here and push the arrow up button above the ON/C button to get the paper feeding through the mechanism. It should pop out at the top!
    Jul 29, 2008 | Canon P200-DHIII Calculator
    Error Code E0200D
    I think making sure the paper is properly aligned fixes that problem. I get it once in awhile.
    Feb 19, 2008 | Canon imagePROGRAF W6400 InkJet Printer
    This suggests debris in one of the feed tracks- get a vacuum to it and give it a good suckout Also take a look at www.fixyourownprinter.com
    May 15, 2007 | HP DesignJet 430 InkJet Printer
    HP DesignJet 430 InkJet Printer Logo
    195 people viewed this question
    Clive
    Clive
    Thomas F. Schneider
