Question about Acer Aspire 3680 Laptop
Can I run my aspire 3680 thru my bose acustic wave ?
Buttons to change time not working
Bose Support - Owner Manuals
worldwide.bose.com/axa/en_au/...manuals/page.html
Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo ... IV ·Wave® SoundTouch music system IV · Acoustic Wave® music system II ... manualsfor home theatre systems and speakers ... manuals for stereo speakers ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
[PDF]The Bose® Wave® Radio Owner's Guide
products.bose.com/pdf/customer.../wrv3_guide.pdf
Bose CorporationThese CAUTION marks are located on the bottom of your Wave radio: ... the user to the presence of important operating and maintenance instructions in this.
Nov 01, 2015 | Bose Wave Radio
I have no audio, (sound) on my Aspire 3680 2682. I do get a beep, but am unable to hear music, videos, etc. My computer keeps telling me that the Audio service is not running but I am unable to turn it...
Hi
Try this solution to your problem.
Look for the speaker icon on your desktop in the right bottom portion of the sceen.
Also when you find it, RIGHT click on it, you will have two choices to make, choose and check each one of the choices to make sure that NONE of the boxes on each
choice has a checkmark in Mute,if there is a check mark then uncheck it.
NOTE:In "Open Volume control: you will find slider to adjust for volume,Wave,CD Player,etc.
After that is down, then LEFT click on the speaker icon and make sure that the slider is all the way to the top and that the Mute does not have a check mark,if it does remove the check.
If that does not work then re-install the audio driver for your computer.
Please take time to rate me thumbs up
Audio driver for Aspire 3680:
http://support.acer-euro.com/drivers/notebook/as_3680.html
Sep 24, 2011 | Acer Aspire 3680 Laptop
My Bose Wave radio/cd won`t play cd`s anymore. The radio works great. The cd player worked tonite, the would stick in a certain part of a song. Very intermittent. Now tries to read the disc, then says disc...
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
Aug 30, 2010 | Bose Wave Music System CD Shelf System
Bose Wave Radio/CD clock running very slow. Now that I've moved it across the pacific ocean(US to NZ) the clock is suddenly running very slow, losing 10-15 minutes per hour while running on any...
My guess is that the clock in the radio is based off of the AC line frequency (not voltage). In the US the line frequency is 60hz (hertz). I'm guessing that the line frequency in NZ is 50hz, which would seem to explain that extreme amount of time loss. I would check with Bose, but I'm betting they make different 50hz models for export.
May 16, 2010 | Bose Wave Radio
I want to have TV sound come thru myBose Radio what connections do I need and where to connect
Assuming there's stereo rca outputs on the back of your tv, you just need an rca audio cable to run from the output of your tv to the input on your Bose.
Aug 02, 2009 | Bose Wave Radio
Need drivers for laptop mainly network drivers
You can download latest device driver for all acer aspire laptop models including your aspire 3680 (both XP and Vista drivers available) @ http://www.downloadya.com/files.php?cat=4
May 28, 2009 | Acer Aspire 3680 Laptop
All Drivers for Acer Aspire 3680
where is ethernet driver for acer aspire 3680
Jul 18, 2008 | Acer Aspire 3680 Laptop
Hooking my tv to the bose
u wann hook up this unit so it plays muci throw biiggger bos system > doesnt big system have cd player this cd only not tv dvd unless it says dvd now then use outputs on back to tv input but i think it only cds
Feb 02, 2008 | Bose Wave Radio
Acer Aspire 3680 Laptop Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
