Question about Denon AVR-2803 Receiver
My AVR 2803 shuts down when volume is at medium or above.
Is this a fuse issue? When playing a DVD or CD the entire system will shut down when the volume is medium or higher. This just bagan to happen. Up to now I have enjoyed superb performance. If it's fuse is it something I can replace?
    Problem Solver:
  • 9 Answers
Too big a speaker load,unit sensors shut unit down when speaker impedance gets too low . and draws too much current at hi volume.A bad woofer or tweeter voice coil burned by sudden excess volume can cause this,also partially shorted speaker wires.
Posted on Jan 03, 2009
AVR-2803/983: Had recent 24hr Power Outage. When power restored, I receive no video/sound from TV thru COMCAST HD box, no video from CD but do get sound, lost partial use of Zone 2. Zone 2 works if I...
Extended power loss might lose memorized settings. Pretend the unit is brand new and verify all of them. No video from CD??? Really? Good luck with that.
Jul 16, 2011 | Denon AVR-2803 Receiver
Hello, I just hooked up our new PS3 Game system to our Denon 2803. Was happily playing it when it cut out on me after about 30 mins of playing. Turned the volume down to see if I was overloadingit but it...
looks like you are overheating it let it cool down for at least 20 min. and then when you use it just lower the volume, after that it should give you no more troble
Dec 18, 2009 | Denon AVR-2803 Receiver
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Avr Shuts down at high volume
It does that because there is a safety feature in all the newer devices. If your system is turned up to high you would blow your audio outputs or speakers. That's why it shuts off.
Jan 17, 2009 | Denon AVR-3801 Receiver
When dvd plays radio comes through as well.
This unit needs to go out for service. There is an issue inside the circuitry in the unit.
Gary
Nov 22, 2008 | Denon AVR-2803 Receiver
Sound cuts out
This sounds to me as an issue not with your AVR but with your cable unit. I have seen this where there is a sample rate issue with the cable boxes. I would try to get another cable box, and see if the issue persists.
Gary
Aug 28, 2008 | Denon AVR-2803 Receiver
Unresponsive remote
Had same problem with this reciever over the weekend. I had to hook up a TV to the COMPOSITE monitor jack and then I could see the menus. I could never get it to show the menu over the component outputs, however a DVD player hooked up played perfectly. Anyone have a solution?
Jan 21, 2008 | Denon AVR-2803 Receiver
Sound cuts out above medium volume
This is usually a heat problem. The more volume you ask of an amplifier, the greater the current (electrical) draw, the more current draw the more heat is generated. This is true of ALL electrical/electronic items.
As you describe it, the fuse is not blowing (stays on) so my choice would be a chip heating up and then shutting down. If that's the case (99% probabilty). The only other reason would be if the unit has an overload switch inside, it would react this way. Either way it's still a heat problem and truthfully nothing you can do.
Try this first though:
Is the Denon dusty inside? Dust can create 2 problems-heat and static electricity. Look through any vents you can get at. If the area around the unit is dusty chances are it is dusty inside. The best way to get the dust out is using a can of compressed air unless of course your vacum cleaner has a "blow" port.
In my shop, when heat is supected I use a can of freon th cool down chips, etc to isolate the component. This is not for a "layman" and strongly suggest bringing it into a shop.
One more question. If the unit using a knob for volume-do you hear a scrating noise when you hit the no volume zone? What happens if you go past the point quickly? I ask because sometimes there can be a bad spot on the volume. The volume knob is basically a circular resistor, whether digital or analog so this is a vague possibility (the other 1%).
If you e-mail me the serial number I can check with the Denon engineering department to see if there are any design problems as it may be a covered repair. It never hurts to ask.
Sorry to be the bearer of bad news
Jeff
Jan 09, 2008 | Denon AVR-2803 Receiver
Receiver shut down only when using phono preamp
You may want to try putting an attenuater in the line with the RCA's to cut the input signal back just a little bit. So you are not driving the amp so hard with your preamp.
Sep 08, 2006 | Denon AVR-2803 Receiver
Denon AVR-2803 Receiver Logo
215 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
