Question about Miele CVA4070 Coffee Maker
Cleaning instructions we have not used machine for a long time
  • 231 Answers
Cleaning instructions are on page 34-45 in the owner's manual.
Please leave feedback. Thank you.
Posted on Jan 03, 2009
My machine hasn't requested a clean cycle in quite a while. Is there any way to start the clean cycle manually?
At the time of set up, Jura instructions ask activating the use of Filter cartridges. This eliminates reminders for descaling.
Throw away the filter cartridges that are expensive, ineffective & block descaling reminders.
Descale the machine every three months using manual descaling method. See link for instructions. Services Unlimited Inc Parts Guru Since 1988
Jun 20, 2016 | Jura Capresso Impressa F9 Espresso Machine
Pfaff 297-1 sewing machine runs very slow.
Your machine appears to be mechanical, not computerized. If so, more than likely your machine needs a thorough cleaning and oiling.
Might be best to take it for a standard service.
If you have the patience and time, you can try fixing it yourself. Consult your owner's manual, clean as instructed, and using Fresh good quality sewing machine oil, apply 1-2 drops as directed.
Wheel on right side that controls the needle up and down is very tight...
In the future, be sure to clean and oil regularly (every 40 hours of sewing, every 6 months if not in use). Use ONLY fresh good quality sewing machine oil, applying 1-2 drops of oil each spot. Consult the owner's manual for instructions.
Dec 27, 2015 | Sewing Machines
Thehook assembly will not move when you turn wheel
Could be a multitude of issues depending on your machine make & model. If it is an older mechanical machine, it most likely seized due to lack of regular cleaning and oiling. Consult the owner's manual for maintenance instructions and use ONLY fresh good quality sewing machine oil & applying only 1-2 drops of oil each spot.
You can take it for the standard sewing machine checkup service.
If you have the patience and time, you can try fixing it yourself:
Dec 24, 2015 | Sewing Machines
Why does my aquasmart machine leave scummy marks on clothes?
Use a cleaning product like Dr Beckmans Follow instructions to the letter .may need second lot to completely cure. Use water softener every wash after.
Nov 03, 2014 | Washing Machines
At cycle start, tumbles one time to the left, one time to the right, fills up, drains and shuts off. Before this problem the washer was pausing during cycle for whatever reason and after checking out the...
Try to clean the discharge pump filter first (Instructions in the Use/Care manual).
If the drain pump is working, it's most likely related to the pressure switch. Check out these postings: Do a diagnostic test -- Easy and free, and the machine will likely diagnose its own problem. Instructions in those postings.
Jan 18, 2011 | General Electric WCVH6800J Front Load...
Clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
Mar 29, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
How do i clean the pump for the delonghi ec702?
you have t use a discaller for expresso machine not vinergar not strong enought follow the instruction on the discaller put product inthe machine with the water start the the machine after a few second turn it off for 10 minute time for the discaller to work repeat untill empty rinse very good that it do that every 3 month thanks pierre
Dec 13, 2008 | DeLonghi EC701 Espresso Machine
Old kenmore machine
just visit our website at
Dec 05, 2008 | Sewing Machines
Try this. It works for the Stainless Steel juicer as well:
Jul 31, 2008 | Jack Lalanne Power Juicer 250 Watts
Not making espreso all the time
Being that you just started using it I would not be concerned. You did the correct thing by cleaning the brew group. Check on your screen under total coffees. We usually recommend you change the brew group every 10,000 cups.
Make sure you descale the machine and you can try using the cafiza tablets to clean your brew groups internal passages.
Brew Group:
Cleaning instructions:
Nov 19, 2007 | Saeco Royal Exclusive 30153 Espresso...
Miele CVA4070 Coffee Maker Logo
187 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
