Question about RCA RCRN03BR 3-Device Universal Remote Control with Green Partially Backlit Keypad
I need the RCA universal remote RCRN03BR code for a Dynex DVD Player DX-DVD2
The package lists Dynex as a compatible brand although there is no dynex code for any device even on the RCA website.
VOTIT
  • 2071 Answers
SOURCE: I bought your RCA universal
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
I have an old KTV, model 13tec and need a new remote.  Which RCA should I purchase RCR 312W or RCR 451??  What code do I use??
Posted on Oct 23, 2008
SOURCE: rca remote control code list
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Posted on Nov 15, 2008
  • 73 Answers
SOURCE: My dvd player plays all DVDs in Spanish if the option is avail.
Some how with that remote, you need to get into the setup of the DVD, and change the SAP or Secondary Audio source. It is set to spanish or to #2 #3 or such.
Charles
Posted on Jan 05, 2009
  • 247 Answers
SOURCE: Can't find the code to program RCA RTD207 dvd home theater system
try these codes:
  • 178
  • 184
  • 205
  • 218
  • 224
  • 228
here is another way to program the remote:
  1. turn the device you want to set
  2. aim the reomte control at the device and press and hold down the code search button for at least 3 seconds until the red led lights up solid red
  3. press the device button you wish to program tv, vcr, dvd,etc and the led light will blink once and then remain solid red
  4. press on/off slowly and repeatly until the device your trying to program shut off
  5. once this occurs press enter button to store the code and the led light eill turn off
thanks
tom
Posted on Jan 08, 2009
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
Have an RCA systenlink4 (RCU440E) and a Dynex DX-R27TV...anyone know the code to enter? I have tried everything and directions...no go!!
2019,2022. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 14, 2014 | RCA RCU440 KIT Remote Control
Unable to program my dynex television, need code
RCA remote control have no set-up code/s to Dynex.
Sep 07, 2014 | Televison & Video
Code for dynex tv with rca system 5
RCA remote have no set-up codes to Dynex brand Tvs.
Aug 31, 2014 | RCA Televison & Video
I have a General Electric Remote Control. I need to find a DynexTV code f
GE remote control have no set-up code to Dynex.
Aug 03, 2014 | Dynex Televison & Video
Xfinity, how to program remote to control DYNEX TV?
Set it up using the set-up codes to Dynex. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
Jul 24, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Tv Code List dynex
Below you will find Dynex codes from the Dynex website www.dynexproducts.com for various brands of remotes
CableVision code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV code: 10463
Dish Network code: 720
Motorola DRC800 code: 0463
One for All code: 0464
Phillips PDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo code: 0091
http://www.dynexproducts.com/c-support/Dynex_Remote_Codes.html
Nov 21, 2013 | Televison & Video
NEED CODE FOR RCA UNIVERSAL REMOTE FOR DYNEX TV
This is the link http://remotefinder.rca.com/default.aspx?site=rca
You enter the model number of your remote control the product type and the brand. Dynex if it is not listed appears to be manufactured with parts from Toshiba and LG. There is a manual with all the remote codes at this link http://support.radioshack.com/support_video/doc66/66871.pdf but keep in mind that codes differ from remote control model number to model number. Hope this helps.
Apr 27, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Looking for universal remote for Dynex brand tv.
I just posted this moments ago:
Well, 'universal' is fundamentally not true anyhow. If your set is newer than the remote, the remote cannot have the complete code set built in and likely no other will either. There are no 'standard' code sets and even if your model was listed, it may not control more than power, volume and channel.
If you want a multibrand/multidevice remote, find one you like, go to the manufacturer's website and check the code list for that particular model number to see if it will be of any use to you before buying it.
NONE of the 'universal' remotes have all the codes sets of all the devices past, present and future. It is a lie and a technical impossibility. ------- While you might find one that can learn to some extent although I have one of those and it won't 'learn' from every other IR remote either.
Oct 17, 2009 | Dynex DX-L42-10A 42 in. LCD TV
RCA RCRN03BR 3-Device Universal Remote Control with Green Partially Backlit Keypad Logo
62 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
