Question about Philips 60PP9352 60" Rear Projection Television
Problem w60 inch using hdtv cable box
Hello all i am a technician for a local cable company , has anyone owning or working on a 60 inch phillips ever come across a shaking picture up and down ,only when using rgb hd connection on port 5 , when using straight coaxial it works great , and it only happens on certain chs , the picture actually appears to be shaking and the owner also says the picture almost scrambles not like pixalation but almost like the hdtv tuner is trying to bring in a non snyc signal . a phillips repairman spent 3 hrs lookin at tv weeks ago and said nothing was wrong , i somehow believe it is a tuner issue , any suggestion , also what are the horizontzl znd vertical snyc inputs for under the hdtv rgb connections??
Set cable box to 1080i output only, the Philips 60PP will then work fine.
Posted on Nov 11, 2007
YOUR PROBLEM IS THIS. PHILLIPS MADE THIS TV WITH 5 INPUTS 1,2,3 ARE FOR REGULAR AIR,CABLE,OR DISH. INPUTS 4 AND 5 ARE ONLY FOR HIGH DEF TV CHANNELS . SO IF YOUR CABLEBOX HAS 100 CHANNELS AND 20 HD CHANNELS,IN INPUT 4 AND 5 THE 100 CHANNELS WILL LOOK SCRAMBLED AND IN INPUT 1,2,3 YOUR 20 HD CHANELS WILL LOOK SCRAMBLED. 99 PERCENT OF HDTV'S MADE IN THE LAST 5 YEARS DONT HAVE THIS PROBLEM BECAUSE THEY READ ALL SIGNALS IN AN INPUT. PHILLIPS MESSED UP BAD HERE AND SHOULD REFUND ANYONE WHO BOUGHT THESE.
Posted on Aug 21, 2007
I know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
Posted on Jun 08, 2007
Does the Phillips 60 HDTV rear projection require an analogue/digital converter?
Unless you are using a cable tv provider to receive your local channels you will definitely need a converter.
Depending on the cable provider will determine if you will need one at that time.
Thanks,
Robert
Feb 16, 2011 | Philips 60PP9202 60" Rear Projection...
This gray box won't go away on my uncle's TV. It says "Video 5 Cable Box" and appears at the upper left-hand corner and won't go away. It has been there for a few days. It's a first. The TV has...
hello my name is rico, you have bad main board, and it needs to replace it, for the square box to go away. if you need more help, call me anytime. 602-810-7149.
Jan 07, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
HAVE PHILLIPS 60 INCH 5 YRS OLD GREAT PICTURE NO
Hi, check for any speaker switches around rear of set that may have been accidentally switched. Could potentially have a "hotel lock mode"
which some philips sets automatically entered after a set time (namely months) which limited volume settings. Your friendly local service technician may be able to help you out with that one
Mar 19, 2010 | Philips 60P8341 60" Rear Projection...
Comcast DVR 3 Remote doesn't work with TV
You may have to use a separate remote control for your TV.
Jun 05, 2017 | Emerson Televison & Video
I have a Samsung 52 inch HDTV LCD television, my problem is that for about 3 days the screen says "One Moment Please" this channel should be available shortly. That is it nothing else for days I am not...
If you have a cable set-top box, then the problem is almost certainly in the cable box itself. If you have a cable card installed in the TV, it could get a little tricky. Either way, it wouldn't hurt to have the cable company come out to check your system for you, whether you need a new cable box, or to try a new cable card in your tv.
I hope this helps you.
Dec 29, 2008 | Samsung LNT5265F 52 in. LCD HDTV
60 inch fresnel screen
Your best bet is to try local TV shops to see if they have any and look on e-bay you may find one there or Place a add in Paper on wanted for tv ?You never know when someone has the same set as yours and lighting hits and most shops sell used screens ,ect what ever is good lefted on set.Have you look under repair service that is listed here on FixYa? Contact some of these shops listed on it! maybe someone has it.Good Luck .
Dec 18, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips plasma 50 inch HDMI cable port being blocked by cable Cable company will not do anything. Cable box explorer 8300hdc It will run for a day or two then the cable port stops working.
There are some ambiguities in the HDCP protocol (rights protection for HD).  When two devices use this one will send a message to the other, it then waits for a response, lastly it responds back.  This is the connection setup procedure.  The issue is that there wasn't a specified time limit that a device must wait before assuming the connection isn't working.  This can cause you to get an error message along the lines of "your tv doesn't support hdcp"  Unfortunately, there's not much that can be done about this.  I spent the better part of two weeks researching this issue with my own television and cable box.  I actually called the cable company and the contractor they use to link them to all of the relevant information but they still insist my tv has an issue.
On the other hand, if you're not getting a message like this you may need to clarify whether you are getting an error or if it's just completely blank.
Mar 13, 2008 | Philips Televison & Video
Need TV code for Emerson HDTV LC320EM8A
I am looking for a remote code for the emerson LCD to work with the Comcast remote...any suggestions?
Dec 08, 2007 | Emerson EWL3706 37 in. LCD Television
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
207 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
