Question about Briggs & Stratton 66set Panzer Tractor Decal 6hp 1960s
Valve timing for B & S 10 hp side valve engine
Inlet valve is very slow to close, not fully closed until almost at TDC on compression. is this normal and if so how can compression be obtained.
Also splutters through carb when starting
  • caird Feb 01, 2009
    Thanks.
    I have since found out the inlet cam has a decompression device that aids starting by reducing compression untill the engine fires and revs increase.This is why the inlet valve timing seems so slow. Centrefugal force overcomes the device, when the engine is running, and valve timing adjusts to normal.
    thanks for trying
2 Suggested Answers
01fordeb
  • 1033 Answers
SOURCE: What would make B&S 15 hp engine constantly go
Sounds like the gas and carb needs a cleaning. The gas may smell alright, but if it's not strong fuel it will cause alot of this. Also the carb needs to be cleaned, such as the bowl and etc. I use starter fluid to clean these.
Posted on Apr 24, 2010
How to set Valve clearence in Mitsubish Lance 1987 Engin model G15B
When Piston 1 is at TDC, (timing points inline), both valves are closed and there should be a gap, say 12 thou on exhaust and 8 thou on inlet. Turn the engine until Piston 2 is at TDC, (both valves closed as with number 1) and adjust, keep going until all pistons have had the clearance set.
Apr 02, 2017 | Cars & Trucks
Valve timing on a 1908 single cylinder petrol car engine with maximum 1200 rpm 6 inch stroke and 4 7/8 bore. what would be the best settings for maximum torque.
way that then was when valve timing principles were being developed that are the same as today
with the piston on tdc exhaust stroke
the cam lobes will be in a position so that a bit of crank movement anticlockwise moves the exhaust a bit and a bit clockwise moves the inlet a bit
as you bring the piston up on exhaust stroke you will see the exhaust valve starting to close and when you see the inlet valve start to open ( at or very close to TDC) that is called valve rock and that is exact valve timing even today
if you have the cam shaft out and want to install it initially bring the piston to tdc and place the cam lobes so one of each would be resting on a valve end , the adjust the teeth mesh to achieve the rock setting as above
as for ignition timing it was set by the levers on the steering column ( or for stationary engine , a lever at the distributor )but ran best about 6-10 degrees btdc Compression ratio then would have been around 7 to 1 and leaded fuel with and a octane rating of 85
it was retarded for easy cranking and starting and when running was advanced to the recommended setting
Jul 24, 2016 | Motorcycles
I have a oz xe 4.1 lt 250 xflow motor which i have rebuilt and put flat top pistons in bored out 60 thou shaved yella terra head 15 thou and has a very mild cam after lining up timing marks the inlet
when setting up the valve timing it is always done on the exhaust stoke.. Place the piston on TDC and set the valve timing so that the exhaust valve is just closing and the inlet is just opening. Rocking the crank a bit before tdc to a bit after tdc will produce a movement where the exhaust starts to close as the inlet starts to open. This is known as valve rock or valve overlap. The cam modification is of no consequence as the as all that is modified is the valve duration , not when they open or close. With the cam now timed to the crank turn the crank 180 degrees and set the ignition timing to the degrees advanced recommended ( 10-12 degrees bftdc is recommended for starting). Place the HT leads in the correct firing order and when running use a timing light to adjust ignition timing. If you are fitting a new cam then you must bedding in grease and when the motor starts it has to be run at around 2.000rpms for around 10 minutes to set (harden) the cam lobes or else they will wear off very quickly.
Sep 28, 2014 | Cars & Trucks
318i timing marks dont have the timing toool need the points of the chain on the cams for 318i
If your gears do not have marks you can pull the # 1 sparkplug, insert a wooden dowel rod, rotate the engine until the piston is TDC.
remove the valve cover on the 1,3,5,7 side and adjust the cam as needed to fully closed valves(compression)
Jul 04, 2014 | Repair Manual for 1992-1998 BMW 3 Series
After top dead center what valve starts opening number 1 intake or number 1 exhaust?
It depends on which TDC you are talking about, compression TDC or exhaust TDC. On the compression stroke, no valves will open after TDC-this is when combustion has occured, the power stroke. When the piston reaches bottom and starts up on the exhaust stroke, then exhaust valve will open. At TDC of exhaust stroke, exhaust valve will be closed, and the intake valve will then open as piston is moving down.
If you have the intake valve opening right after TDC, you are on the exhaust stroke of that cylinder. The exhaust valve is only open during upward movement of the piston on the exhaust stroke. Immediately after TDC of exhaust stroke, the intake will open as the piston travels downward.
Mar 04, 2014 | Mitsubishi Cars & Trucks
Valve clearance for mitsubishi L200
Take the rocker cover and the upper timing belt cover off.
Set No 1 Cylinder to TDC - use the markings on the cam spocket to get this - and confirm it's on the compression stroke by check both inlet and exhaust valves are closed and on the heel of the cam.
In this position, check rockers 1,2,4 and 5.
Take care with the feeler guage to make sure you're right under the pad under the adjuster screw properly and completely passing under it, not sticking part way.
Rotate the engine (crank shaft) 360 degrees. This should bring No 4 to TDC - confirm that both inlet and exhaust valves are closed and on the heel of the cam.
In this position, check rockers 3,6,7 and 8.
Clearance for Intake and Exhaust is 0.25mm at normal engine operating temp.
Don't forget to fit a new rocker cover gasket and half moon seal (use something like Hylomar to help make sure the half moon is sealed properly - usual suspect when rocker cover leaks at the back of the engine).
Jan 05, 2013 | Mitsubishi L200 Cars & Trucks
How do you remove timing chain and re-time eng
If you need to remove the cylinder head, here's how. To remove the cam chain, you've got to also remove the left crankcase cover and flywheel.
First, you need to turn the engine over until the piston is at top dead center (TDC) of the compression stroke. Begin by removing the two round covers from the left side of the crankcase cover. Also remove the four tappet hole covers from the cylinder head cover. Turn the engine (in the normal direction of rotation) and watch the intake valves open - and close, then see that the exhaust valves open, then close. Now align the 'T' on the flywheel with the notch in the inspection hole. With all of the valves closed, the engine is at TDC of the compression stroke. Do not begin removal of the cylinder head cover until this is done - to avoid damage to the cover.
With the cylinder head cover removed, you will find two bolts attaching the cam chain sprocket to the camshaft. Turn the engine until you can get a 10mm socet onto the heads of the bolts and remove them. The sprocket will come loose and slide down onto the camshaft, enabling you to remove it an the camshaft.
Upon reassembly, set the cam timing by first setting the engine at TDC. Then, align the two marks on the cam sprocket with the gasket surface on the cylinder head. With the engine at TDC and the marks lined up, the cam timing is properly set.
Oct 24, 2009 | 1985 Honda XR 250 R
How do u remove timing chain and re-time engine (1984 xr 250 r)
Before calling the job done, make sure to adjust the tappet clearances to .002" on the intake and .003" on the exhaust valves.
Decompression problems --cam shaft looks in good condition but it is not decompressing when turning over,the valves have been set at tdc @ .15 mm ,the cam is stock pn # 58436010044 the cam is sold as an...
the valve clearance is incorrect at .15mm ( .005") it should be at .010"inlet and .012" exhaust and is set on tdc but on compression stroke tdc
decompression cams have a special grind that holds the valve open for starting revolutions and as the engine rpm picks up the cam follower doesn't follow the profile any more and closes the valve
engines that utilize such a cam are motors that have a rating exceeding 3 hp on a rope pull otherwise , the piston cannot be pulled over compression past enough to get it started
5 hp lawn mowers , 10-20hp rope pull generators etc have this cam
Dec 09, 2017 | 2003 KTM 625 SXC
No compression 2003 jetta 1.8L Turbo Timing belt is on and tight, timing chain is on and tight, pistons are going up and down, valves appear to be opening and closing. no funny engine noises, engine turns...
Either the camshaft are seriously out of time or the piston rings/pistons are worn out.
Check TDC of Piston No1 on the power stroke coincides with both inlet and exhaust valves being closed.
Oct 09, 2009 | 2003 Volkswagen Jetta TDI
Briggs & Stratton 66set  Panzer Tractor Decal 6hp 1960s Logo
110 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
