Question about Makita Saws
I need an Owner's Manual for a 14" Makita Miter Saw model number LS 1430.
Electronic version would be preferred.
efs_perpends
  • 1996 Answers
SOURCE: Cant find owners manual for Delta compound miter saw model Ms250
Go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Posted on Mar 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: I need a user's manual for a Delta MS250 Miter Saw
I have nothing to do with the product list, thank you. But the information you are trying to find is located at Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and on the following page go to the listing at the left for the schematic and open it, you will see another selection for instruction manuals go to the last one which is in English. If I have answered your question please rate this information accordingly and thank you.
Posted on Jul 10, 2009
SOURCE: Makita LS1013FL manual missing
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/LS1013 then download manual
Posted on Sep 11, 2009
VtToolMan
  • 704 Answers
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
maadgar
  • 44 Answers
SOURCE: Makita LS1030 miter saw, base doesn't rotate as
dust and debris get under the plate; remove the fence from the base and the lock mechanism from the plate; flip saw over and remove the retaining nut from the spindle, the base should pull easily away from the plate.thoroughly clean the bottom of the plate and the top of the base and check for/remove any imperfections in either with emory cloth. use a mineral oil based lubricant when reassembling and be careful not to overtighten the retaining nut.blow out the base after use with an air gun and lube lightly after each day's use to avoid this in the future
Posted on Nov 18, 2009
Makita LS 1000 miter bed does not turn freely; probably jammed up with saw dust. What is the best approach to cleaning the rotating bed?
PDF]TECHNICAL INFORMATION - Makita
www.makita.nl/images/files/onderdelen/nl/LS1020-TE.pdf MAKITA 255mm(10") Miter saw. Models No. Description. New Tool ... Optional accessories. The main specifications are common with #LS1000. Saw blade:.Missing: bed
Jul 22, 2015 | Makita Saws
The motor brake on my pro tech miter saw doesn't function. Is there a doable fix ? Also need an owner's manual
The brake on saws like yours are controlled by the switch. They do go bad and are easily replaced if the parts are still available. Your heading says you have a Makita tool but you didn't give the model number. If you go to the Makita home site at:
www.makitatools.com/en-us/Modules/Home/Default.aspx
you can put your model number in the search box and get a parts breakdown and owner's manual if they are still available. Parts are available online at sites like www.ereplacementparts.com where you can also get a parts breakdown but not manuals.
Jun 06, 2012 | Makita 10" Dual Bevel Sliding Compound...
Does anyone know where I can download, for free, a user manual on a 10" Makita LS1030 Miter Saw? My neighbor gave it to me, but didn't have a manual.
Yes, go to "makitausa.com" and in their search on the right upper side of the site type in your model number and it will redirect you to a page so you can download the manual and also a parts breakdown if you need one. Let me know if you need more assistance and if I have helped you would you please vote accordingly. Thank you
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
I have a Makita LS 1013 compound miter saw. The locking knob that locks the saw from sliding back and forth no longer works. I downloaded the owners manual and parts list but I can't seem to correctly...
check position 79 the spring that pushes against the table and also the end of the locking knob to make sure not rounded over/worn not applying pressure to the locking spring.
Dec 19, 2010 | Makita 10" Miter Saw LS1030N
Need to re assemble trigger of ls1040 mitre saw, is there any instructions
go to MAKITA TOOLS.COM under benchtop on the menu select miter saws and your model number once in there there is a menu showing instruction manual, parts assembly and you can geta full print out diagram of how it should go together
May 03, 2009 | Makita 10" Compound Miter Saw LS1040
Makita table saw switch wiring
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Mar 01, 2009 | Makita Saws
Yes go to Makitausa.com and type in your model number and you can download an owners manual for the tool. Let me know if you need any more help
Feb 15, 2009 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Saws Logo
131 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
