Sony PS3 LED Display Red Blinking Light
Hello, Could somebody please help me this problem, I have this Sony PS3 LED Display http://store.sony.com/p/24%22-PlayStation-3D-Display-Bundle/en/p/PS398078 Which had worked fine, but suddenly one morning it's flashing a red light on the bottom part of the screen, where there is a green light for power on indication. When I turn on the device, the green light comes on and then after few seconds the red flashing light comes on and the the display died. Any help would be really appreciated.
  • 668 Answers
SOURCE: Sony Vega KDF-E5OA10,picture will not come on, tv goes off.
There is a real good chance that the lamp fan is not turning. If you look with a flashlight in the vent on the left side looking at the rear of the set and have someone turn on the unit, see if it spins. if it doesnt, the protect circuit in the tv will not let the set turn on. Replacing the fan will cure the proplem if it is not turning.
Hope this helps,
Skyassoc
Posted on Jun 18, 2009
dsacco86
  • 1077 Answers
SOURCE: red light blinking, tv doesn't start
Your TV is in Protection Mode right now. A part inside the TV has failed and the TV will not turn ON to prevent other parts from being damaged. The red light blinking is an error code for diagnosing the problem part on the one of the power supply boards. The problem boards that need to be looked at is the Backlight Inverter Board or the Main Power Supply Board.
There is a slim chance you can leave the TV unplugged for an hour so the TV can discharge and reset itself. But other than that, I would use the warranty if possible. The TV repair shop maybe expensive, so get some price quotes to see if it worth the trouble.
Posted on Sep 09, 2009
  • 8909 Answers
SOURCE: I have sony Bravia KLV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Mar 09, 2011
vinceisaac
  • 2432 Answers
SOURCE: lg 47lk520 reset
tried first to disconnect the supply connector going to the inverter board for back light just to ensure if their is no shorted component here. and then turn the power on again if the light stay then the inverter board was the cause why won't power on. by the way did you make a voltage checking at the power supply board does it have correct output voltages 5v,12-16v and the 24v.
Posted on Sep 19, 2012
vinceisaac
  • 2432 Answers
SOURCE: Hello, I have this Sony PS3 3D LED Display and it had worked just fine for few months. Day before yesterday, when I turned it on it's giving me that blinking red light which I had do described in
tried with unplug and re plugged doesn't work?.
Posted on Oct 29, 2012
Red light is blinking 6 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name and type of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 04, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
Play station 3 won't turn on the red light goes on then blinks and turns off
PS3 show red light and blinks then turn off - Somebody have the same problem and a solution is here :
PS3 Red Light Blinking Fix
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Was browsing internet via ps3 an it just went off!! tried to switch it back on, the green light came on for second then changed to a yellow colour then went off again but the red light just kept blinking,...
Hello, unfortunately this is called YLOD (yellow led of death) it is reported to happens on phatty PS3. There are few guides online with DIY methods to get rid of it, but you must have good soldering skills and understand that you might compromise your console even more. If you don't have the above mentioned skill, then the best and safest solution for YLOD is to call Sony support. If you still have warranty coverage, the fix will be for free, if you're out of warranty then they usually ask about 120/140 USD, but they'll give a 3 months warranty. Good luck anyways Peter
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
Console will not accept any discs. triple beeps and red light starts blinking
Hello new club member. thank you for not willingly joining the "da-gumit my ps3 is flippin broken club" please read on for details.
You have the dreadful blinking red light of death. Long story short the system is broken due to overheating and heat damage to the motherboard and you have a few options:
1. send the system to sony and receive a refurbished system for $150.
2.find a local to do it for much cheaper
3.watch vids on the web (youtube.com) and fix it yourself but it is fairly difficult
4.buy a new ps3.
I hope I have helped and please feel free to ask me any questions and let me know how it goes.
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
PS3 Controller mult lights lit on controller
IM not sure but on the main menu of the ps3 go to settings then to accesorries settings then go to reassign controllers then if its on another number than 1 put it to 1
Nov 29, 2009 | Sony Video Game Consoles & Games
Wont turn on has blinking red light wont stayed powered
Hello, I'm sorry to say this but the blinking red light is = the light of Doom. Your PS3 is dead. This is somewhat like the XBOX Red ring of death.Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony and they will send you a new or refurbshed one. Your ps3 is one in a billion (according to Sony). North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
2. You could try this article, if you choose to, it's a long shot but might work for you in your case. http://ps3.qj.net/Possible-PS3-flashing-red-light-fix-from-MXACE/pg/49/aid/75721
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
Console wont turn on has blinking red light wont stayed powered on and can't get game out
My ps3 brinks red
Hello, I'm sorry to say this but the blinking red light is = the light of Doom. Your PS3 is dead. This is somewhat like the XBOX Red ring of death.Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony and they will send you a new or refurbshed one. Your ps3 is one in a billion (according to Sony). North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877 Now you could try doing a few things (hey it's worth a try!)
Nov 21, 2009 | Video Game Consoles & Games
Bar light turns from green to yellow to blinking red
this is similar to the red blinking lights on the xbox360...it seems your cell processor has overheated resulting in a cold solder joint or worse bridged solder involving the BGA array...I have had some sucess in fixing these albeit limited. sony charges 150 plus state tax and sends you a refurbished unit.
Nov 11, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Electro Med Services...
