Question about Dishwashers
Reset sequence for kudk02crbs2
I need the sequence of bottons to push on this particular model to reset the dishwasher or run the diagnoses
4 Suggested Answers
SOURCE: Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Mar 24, 2008
  • 25 Answers
SOURCE: KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
try the reset button sequence i posted in the other question..
Posted on Jan 24, 2009
  • 93 Answers
SOURCE: reset model smu7052uc
there is none- if the program is mucked up-- pull the plug for 5 minutes
Posted on Jul 16, 2009
Kitchenaid kudk02crbs2 dishwasher normal button not working
In this situation you must replace the control panel
Dec 02, 2016 | KitchenAid Dishwashers
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
Cant get dishwasher to run and it is stuck on heat dry
Hi, iIt sounds like it needs to be rebooted, like a computer. Shut off the breaker for a few seconds and reset it. If it has a digital panel there is normally a button pushing sequence you push to clear out it's memory and get it back to square one. If you can't find the sequence in your manual, call the CS number and ask them how to clear the digital panel memory.
Jun 11, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Filter light status
Please verify the model number for your fridge, as the description shows a Frigidare 24" dishwasher.
With the model number and you providing the different buttons on the front panel, I can provide you with the button sequence to push and hold to reset the filter light.
While waiting for the needed info for an exact solution, you can try this:
If you have a "light" and "lock" button, push and hold them together for several seconds, the filter light should go off or change back to green.
If not, please provide me with the brand and model number for your fridge so I can give you the correct procedure for resetting the indicator light, by responding back with a "comment".
Hope you find this Very Helpful and best regards!
Aug 18, 2009 | Frigidaire Professional Series 24 in....
Reset model smu7052uc
Jul 16, 2009 | Bosch 24 in. SMU70 Built-in Dishwasher
Dishwasher won't stop running
OK,, this seems to be a control fault. this is usually fixed by unplugging for 5 minutes and resetting the control.
as you stated, you have done this reset and the issue is still a problem at this point. this basically confirms the control fault within the control assembly and sequence switch.
This is easily fixed by replacing the Control assembly and sequence switch. the affected parts and their respective part numbers are listed below.
Control assembly ----- Part number # WD21X10116 $148.75
Sequence Switch ----- Part Number # WD21X10018 $99.75
this will fix your dishwasher.
Please rate and god bless:)
Apr 28, 2009 | Dishwashers
Need Reset code button sequence
Hi ez_drummin02,
The following link will give you step by step instructions for unlocking the controls on your dishwasher. Simply get your model number off your dishwasher and enter it into the box. The owners manual will tell you how to reset the board and locks if you have engaged the lock. http://shared.whirlpoolcorp.com/product_literature/search.jsp
Hope this will help.
Mike
Sep 29, 2008 | Dishwashers
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Dishwashers Logo
19 people viewed this question
Top Dishwashers Experts
