Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
Where can i buy the potentiometer for my line 6 spider lll amp
paulm10
  • 73 Answers
SOURCE: line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Posted on Jul 09, 2009
  • 88 Answers
SOURCE: I have a line 6 Spider III, 30, 30 watt. when I
possible software problem
Posted on Feb 04, 2010
  • 5603 Answers
SOURCE: where can i get the manuals for line 6 IV 15 amp
User manuals here:
http://line6.com/support/manuals/?families=45&submit=Submit&1st=1st
Posted on Apr 15, 2010
  • 5603 Answers
SOURCE: My Line 6 Spider Amp sound goes out when I plug in
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
Posted on May 07, 2010
  • 5603 Answers
SOURCE: What causes your line 6 spider amp to turn on and ...
This MAY be due to overdriving the amp. The single chip amplifiers used in these have thermal protection usually and will cycle on and off if you drive it too hard. This is a tiny amp and is for use as practice and is NOT suitable for heavy use. Most of these use chips like the TDA 2050 and MANY of them have VERY substandard heatsinks and often don't even use thermal conductive grease under the chip.
If you want loud, then you need to step up the size of amp you are using to say a 100 Watt one that is designed to take the power.
Posted on May 21, 2010
I have a Line 6 spider 3 of 150 w, and i buy a floordboard, when i connect it, the pedalboard damage my amp, burn the processor Board, and i dont know where to buy this part.
It is NOT likely that any significant damage was done to the amp. Find a COMPETENT tech that knows how to fix, rather than replace boards.
May 31, 2011 | Line 6 Spider III 150 Guitar Combo...
What causes your line 6 spider amp to turn on and off while using
May 19, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
My line 6 spider iii30 30 watt amp works with
There is likely a switch contact on the headphone jack that routes the amp output to the speaker. These jacks on most music stuff are JUNK and the contact may not be closing.
If the spring contact is bent so it won't close you can bend it to contact BUT the springyness usually is gone and the contact will be marginal.
May 10, 2010 | Line 6 Spider Iii 30
My guitar won,t play threw the amp lots oof static
The things to check arre FIRST the cable. These often have breaks or bad connectors. Replace with known good one and try it.
Next are the jacks on the guitar and the amp. These go bad and wiggling the KNOWN good cable at each end will flag which or both being bad.
Next are the switches and potentiometers in the guitar. Use some CRC226 sprayed into the pot and switch contacts... use sparingly...
The key is to find which thing or things are bad.
Sep 15, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Line 6 spider III 15 watt sound problems
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
47 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Larry Stiles
Larry Stiles
carey w mason
carey w mason
Are you a Line 6 Music Expert? Answer questions, earn points and help others
