Question about Nordic Track Audiostrider 800 Resistance 236672
Pedals wount move
My machine pedals are very hard that they wount move
    Problem Solver:
  • 7 Answers
OIL IT. IF That doesnt work go to justask.com and they will help.
Posted on Oct 30, 2012
My empisal design 800 is only 12hrs with me, the manual knob is hard doesn't wanna lift up the needle also the electronic pedal when I step on it it just make noise but doesn't move the needle at all
If it's a brand new machine, immediately return it where you purchased it. They should provide you with a properly working machine.
Dec 10, 2016 | Sewing Machines
Sewing machine slow in forward but fast in reverse
the speed is controlled by the foot pedal perhaps it needs replaced
Jul 04, 2015 | Sewing Machines
YAMAHA OLF CART GASOLINE OPERATED CHARGED BATTERY WHENi TURN KEY ON AND TRY TO GO IT WONT MOVE AND A SLIGHT WHINE
Check the starter solenoid, but sounds like the starter is bad. If it is draining the battery when you try to start it, then it is the starter. Check for a bad ground first though. The starte requires a great deal of amperage and a weak ground could be the problem.
Feb 15, 2014 | Cars & Trucks
How to know a bad fuel pump?
maybe you have bad gas .
Nov 09, 2011 | 1998 GMC Jimmy
Looking for the model 117 manual, preferably free. When I hold the pedal down, the machine just hums and the needle doesn't move.
The company has different options for manuals, including hard copies and a free download.
Try this link:
http://www.singerco.com/uploads/download/06c0bd9ebc88275cba283af9247a5db581336739.pdf
Dec 21, 2010 | Singer Featherweight II 117
I have 2001 Chev Tracker, Oil started to run out of the Right side break drum. Removed Drum and foud oil all over the breaks. Tried to remove the Axel by removing the four nuts off of the backing plate,...
The axle requires a slide-hammer to remove. And usually the axle bearing is destroyed in the process. A new axle bearing needs to be pressed on by a machine shop, and then the reinstall of the axle requires the correct application of concussive force. This is NOT for the faint of heart, or the ill-equipped!
Are you sure the brake cylinder on the affected side isn't leaking? It would spray oil everywhere, and is MUCH easier to fix. You would tell this as the brake pedal would move easier than it should.
Jul 21, 2010 | 2001 Chevrolet Tracker
I have a singer 514. I recently got a new foot pedal. When I press the pedal The machine motor runs hard, but nothing happens without moving hand crank -- and it will stop "whenever"
Sounds like you need to open the foot control and adjust the carbon bar, you will soon see it, just undo the screw and move it away from the contact or adjust the screw in the end.
Sep 12, 2009 | Singer Sewing Machines
When i press the pedal on my sewing machine the pedal doesn't move. Sounds like the belt is working really hard but not catching. I can manually spin the knob and make it spin. Is this an easy fix?
It most be the belt. some belts have knots to catch the wheel. same use smooth belts. check to see which one it uses.It may have stretch out get a new one.
Aug 06, 2009 | Yamata FY900 Mechanical Sewing Machine
Nordic Track Audiostrider 800 Resistance 236672 Logo
56 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
