Question about Seagate Expansion 2TB USB 3.0 Desktop External Hard Drive
No performance 2tb dont know how o turn on
  • Seagate Master
  • 27,725 Answers
Figure out whether you need a hardware or software fix.
Look for grinding sounds from your drive or humming that starts or stops.
These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out.
If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix.
Run one of the many software fixes, if you think the problem is related to software.
These programs feature on-screen directions, making it easy for you to progress through them.
If this works, you don't need to fix a physical problem.
Remove the many tiny screws that holds the drive together.
Eventually, you'll get to the innards of your drive.
Be very careful not to bend or force a piece to go where it doesn't want to.
Determine if you've set things straight.
Look to see whether anything was loose inside your external hard drive.
If you have recently dropped it or traveled with it, it is possible that something came loose.
Also check that all the arms and platters are straight and do not appear bent in any way.
If they are bent, straighten them with your hands or pliers.
Put everything back together and check that everything in your external hard drive is working properly.
Try using the external hard drive on another computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb but its not working ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Posted on Oct 30, 2012
Hi, I got a 2TB Seagate Goflex External Memory. I've bought it in US and Now I am in Colombia. The problem is that I for got the power cable, so I've tried with other one with same characteristics,but it...
I don't know if you can open it up, but inside there is a hard drive that you could attach inside a desktop - you will void your warranty by opening it.
Sending it in for warranty repair is risky - they usually will not try and preserve any data.
I think your unit is toast.
Feb 26, 2015 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Freecom usb port broken away from circuit board inside enclosure
It is hard to buy replacement for the same enclosure, but there are many USB2.0/3.0 enclosures available on the market for 2.5 and 3.5 inch drives.
Make sure read reviews for issues and performance on those enclosures.
Apr 10, 2014 | Freecom Xs External Usb Hard Drive 2tb
Toshiba DWC120 2TB Harddrive not recognised
Before connecting anything to an USB port you need to install the software for the device. Then you can connect it.
But when you have an old laptop it could be it can't handle the 2 TB.
First install the software that came with the drive. Then see if the laptop can handle the 2TB.
Dec 20, 2013 | Toshiba 2TB Desktop External HDD Hard...
TRANSCEND 2TB cant connect to my PC
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
http://www.cleverfiles.com/
hope this helps
Aug 10, 2012 | Transcend 2tb Storejet 35t3 Usb3.0...
My Lacie Hard Drive only shows 9.99 mb capacity. and its a 2TB LaCie d2 Quadra v2.1 7200RPM U. It was just repaired by Lacie. Where's all the storage?
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
Hdd seagate 2tb suddenly not work i connect and the light flash and my pc and mac dont read the hdd pplease help
Hello OS,
The GoFlex Desk external drive have ample storage capacity and it's easy to upgrade to any interface you need.Pairing the desktop hard drive with a GoFlex USB 3.0 or FireWire800/USB 2.0 adapter to increase your performance by up to 10 times. Works interchangeably between a PC or a Mac® computer.
Please visit the link provided below :
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=214431&NewLang=en
Jun 07, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
I have a Western Digital WD20EADS 2TB hard disk, within a fantec MR-35US2 disk case, connected with a USB to my computer. The problem is the disk is performing to slow.
sometimes when a hard drive is performing to slow it is because there isn't enough Random Access Memory (RAM) in your tower or laptop all you have to do is upgrade the RAM to 1GB - 3GB is will ensure the hard drives performance will increase
details of what RAM looks like
http://www.google.co.uk/images?hl=en&q=random+access+memory&rlz=1R2ADFA_enGB408&wrapid=tlif12927122991681&um=1&ie=UTF-8&source=og&sa=N&tab=wi&biw=1072&bih=587
Dec 18, 2010 | Western Digital WD20EADS 2 TB SATA Hard...
Seagate Expansion 2TB USB 3.0 Desktop External Hard Drive Logo
182 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
