Question about Jeep 2003 Liberty Sport 3.7 V6
2003 jeep liberty
Overheated and shut off..Could start back up about 45min later..Noticed leaking of coolant/water onto the starter under the driverside but cant see exactly what it is that is leaking. Does anyone have an idea?
  • Jeep Master
  • 14,411 Answers
You may have blown head gasket.
Posted on Oct 31, 2012
Can i drive my 2010 jeep liberty with a leaking heater core?
The heater uses the coolant (read antifreeze and water) from the engine to get hot. If it runs low enough, by say leaking out of the heater core, your engine will overheat and that can be bad for it and expensive to fix.
Although most antifreeze is poisonous, (don't drink it) if you keep your window open the fumes will not hurt you. That being said, it will stain the carpet, make the inside of the car smelly, leave a puddle on the floor, cause the floor boards to rust(slowly) and mainly be annoying.
Since we are starting into summer you can get by for awhile by just adding water to the coolant tank under the hood. Make sure you do this when the engine is not hot. Engine coolant can give you severe burns if you take the cap off when the engine is hot.
So, about an hour after you get home from work go and check the engine coolant level. If you can hold onto the radiator hose then it is cool enough to add some more water. If you add more water then leaks out you can drive the jeep.
FYI The leak will get worse over time.
May 14, 2014 | 2010 Jeep Liberty
2003 jeep liberty overheating and steering issues
your water pump might giving out the will cause an overheat and your power steering to give out, the water pump is and cheap and easy fix cost about 80.00 all together with the coolant you can do it anywhere as long you got tools to do it
Mar 29, 2013 | 2003 Jeep Liberty
2003 jeep liberty sport overheating and no heat is coming from heater
If it is just a fluid issue, the problem is that there is air in the system, and every time air gets to the water pump, it can't pump anything. You need to pull it up on a sharp incline (as close as you can find to 45 degrees, run it for a bit and then turn it around on the hill to force the air out of the system.
HOWEVER, I'd bet that it's the water pump. The water pumps used at that time had plastic impellers, and they disintegrate and little chunks get all through the coolant system. The dealership wanted almost $1,200 to replace it and I had to leave it for a week. I limped down the street to Firestone Auto Care and they did it for $450 in four hours. 50,000 miles later, no problems.
Mar 16, 2017 | Jeep 2003 Liberty Sport 3.7 V6
2003 jeep liberty wont start
Could be the battery, the starter, or a bad connection between the battery and starter.
A mechanic would check for voltage and ground at the starter first.
Dec 09, 2012 | 2003 Jeep Liberty
2003 Jeep Liberty leaking pale yellow fluid from very front of car-at first I thought it was water-haven't been running AC
sounds like coolant and that vehicle overheated or now has a leak ---and replacing plugs usually doesnt correct an overheating problem and if told had bad thermostat [ which will cause overheating ] i would have system tested for leaks then look into thermostat as a problem to your overheating problem
Aug 23, 2017 | 2003 Jeep Liberty
My 2003 jeep liberty 3.7l overheated and then I realized I had no coolant so I fill the resivior up with coolant and started the jeep, but it began to drain rapidly...with no signs of leaks anywhere. So I...
YOU HALF TO FILL THE RADIATOR DIRECTLY THER WISE THIS WILL OCCURE DO TO THE RADIATOR BEING SO FAR DOWN. NOW IF YOU OVER HEATED PULL YOU OIL DIP STICK AND IF THE OIL LOOKS LIKE CHOCOLATE MIKE THEN YOU BLEW THE HEAD GASKET AND WILL NEED TO FLUSH THE MOTOR AND REPLACE THE HEAD GASKET AND OPE PRY YOU DIDNT SCORE ANY OF THE PISTON WALLS
Aug 04, 2011 | 2003 Jeep Liberty
2002 jeep liberty 3.7 - same prob as barbara_ I_bo did on Apr 11. Overheated, changed thermostat, noticed belt was worn, changed it, flushed radiator, now idles rough, misfires, will drive but prob...
I've herd that on high mileage vehicles that the veins of the water pump can actually erode away. Maybe cheap metal or old coolant or wrong coolant.
Jun 15, 2011 | Jeep Liberty Cars & Trucks
2003 jeep liberty overheating still. Hello, I own a 2003 jeep liberty 3.7l sport and its been having problems ever since i got it. At first i just had to replace the water pump then i had to replace the...
I had the same problem i change the bottom hose and the water pumps inside came loose replaced water pump....Also it has a bleeder by the top hose by battery get the air out.....
Jun 01, 2011 | 2003 Jeep Liberty
2005 grand cherokee squealing and loss of coolant
Check belt tension, squeeling is most likely due to belt slippage. Have you noticed any fluid leaking from under your Jeep? Coolant level drop could be from bad water pump, when the pump needs replacing, water flows out of a "weep hole". It could be leaking onto your belt also, causing it to squeel
May 16, 2010 | 2005 Jeep Grand Cherokee
2.3l ranger keeps overheating, been through two radiators already.
Hello Ranger Joe, eight months and two radiators is very uncommon. Question, Have you visually confirmed the leak in the radiators or is the leak near the hose connections? Replacing the radiator, cap, water pump, & the thermostat leaves only two others, the hoses and the engine block/heads. Far fitched will be something or somebody poking holes in the radiator.
Nov 07, 2008 | 2003 Ford Ranger Regular Cab
Jeep 2003 Liberty Sport 3.7 V6 Logo
112 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Stan Ford
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
