Question about ASUS P5SD2-X Motherboard
Compatibility of IntelD 830 CPU wit Asus P5SD2-X board
Asus compatibility list shows IntelD 820 and D840 CPUs are compatible with this board, D830, also a Smithfield in the same range, is not mentioned. Is it compatible?
  • ASUS Master
  • 3,799 Answers
If the manufacturer hasn't mentioned it then it is either not compatible, or it is the wrong CPU socket.
Posted on Oct 30, 2012
apple_rom
  • 40 Answers
SOURCE: Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Posted on Oct 04, 2007
Buschchris1
  • 474 Answers
SOURCE: Compatible Graphics Card for ASUS P5LD2-VM SE Motherboard
Your board is PCI EXpress so as long as you get a PCI express Video card you should be fine. Just dont get a video card with a Faster Bus speed than your Mobo or else its wasted potential, but other than that, ** problem, have fun playing video games :)
Posted on Mar 10, 2008
map9966
  • 2351 Answers
SOURCE: ASUS P5VD2-MX SE Motherboard CPU compatibility
Hello itsme99, click on this link I have posted. This link shows what CPU you're Asus P5VD2-MX SE motherboard can run.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5VD2-MX%20SE
You're board does not support Quad core CPU's!
This next link is the main page (Drivers, FAQ's ect.) for the Asus P5VD2-MX SE motherboard. (Look to the left of the page under Related Link). http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Here is a list of Asus Quad core motherboards.
http://event.asus.com/mb/quad_core/
Have a nice day.
Enjoy!
M
Posted on Jun 06, 2008
Nic61
  • 1073 Answers
SOURCE: Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Nic
Posted on Feb 06, 2009
SOURCE: Asus P5GZ-mx compatible graphics cards
Basically, any graphics card is capable of being compatible with this motherboard. I had some difficulties for a while until I figured out you have to MANUALLY set it to use your PCIE 2.0 GPU output.
How to do this is to set your jumpers to external output only. First thing you'll want to do is update the BIOS on the motherboard (Which you can do by getting "Asus-Update". Find it on google, easy to use, just make sure your computer doesn't crash during the BIOS flashing.
Afterwards, set the jumpers to use your PCIE-2.0 slot. Took me a little while to figure this out, and it's a little hard to explain.
Above your PCIE-2.0 slot there are 5 little blue 'plastic-like' things. Those are your jumpers. Take them out and insert them HORIZONTALLY as such:
Basically, make sure the jumper things are connecting the little drawing there. They HAVE to be horizontally inserted, otherwise this WILL NOT WORK. Just plug in your monitor to the graphics card's output, and you're good to go. Hopefully it works for you.
Posted on Sep 05, 2009
How to check for Asus UDQF2PH62BAS CPU FAN compatibility?
The only way to see if this replacement part will work for you or not, your product's Part Numberhave to be the same with our replacement Part number. If it's on the list, then it will be compatible. (Your Deivice Model number is not good enough to verify correct product).Part numbers can be located on your Asus UDQF2PH62BAS Cooling FAN or you can check your user's manual. Another way to check for compatibility would be to check the listing within the "Fits the following model." The list will provide you with the product model that would be compatible with the List item. for more information : www.2egoo.com
Mar 28, 2012 | Computers & Internet
Their is no driver compatible for my asus p5sd2.. my operating system is windows 7.. pls help.. tnx
Don't you worry, your driver will still be usable. Before you install any driver into a windows 7 computer, you should use troubleshoot compatibility. It will allow you to choose on what type of Operating system you would like your program to run with. Right click the icon of your program installer then choose troubleshoot compatibility afterwards. Maybe, it's because of the incompatibility of your driver. Reply back if it still does not work:D
Nov 21, 2010 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Which graphics card?
You can use any PCI-E graphics card in this slot. This motherboard is limited to x4 on this slot though. Any board will FIT, but they will be running four times slower.
Jan 06, 2009 | ASUS P5GL-MX Motherboard
CPU compatibility
This motherboard is not compatible with a Dual core processor since this is a old Motherboard a;ready and only supports Intel Celeron, Intel Pentium 4..
Dec 31, 2008 | Soyo SY-P4I845PE Lite Motherboard
Motherboard compatibility
Which P4 3.0Ghz CPU do you have?
is it socket 478 or LGA-775?
Best thing to do is figure out what brand of motherboard you would prefer and then go to their website and look at their CPU compatibility chart for your CPU to find out which models support it
I personally would recommend ASUS motherboard and you can check out their compatibility chart here: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
Or if you prefer a different brand of motherboard you can find links to allmost every brand here: http://www.motherboard.cz/cpusupport/
Hope this info helps
Nov 24, 2008 | Intel Computers & Internet
Cpu upgrade wont happen
Ok i checked the ASUS website and looked up the CPU compatibility list for your board here:
But unfortunately that particular CPU doesn’t seem to be supported. Must be something to do with the technology inside the CPU or the amount of L2 cache or something like that. (it would require some rather intensive research to find out exact reason why...
And when searching for ASUS motherboards that are compatible with that CPU it comes up with this short list;
AP120-E1
AP130-E1
PSCHL009
AP140R-E1
P4RD1-MX
Did you clear the cmos when installing the new cpu before powering it up?
i know the CPU you have now runs at 400FSB and the new one runs at 800FSB But that board supports both speeds so that shouldn’t be a problem.
What type of RAM do you have ?
maybe check owners manual for memory compatibility chart for new 800FSB CPU
Have you tried the latest beta bios from ASUS site :
I can not guarantee that it will work but it is worth a try.
http://support.asus.com/download/download.aspx?model=P4S800D-X%20&f_type=34&SLanguage=en-us
NOTE: Updating the bios can be risky and should only be done to resolve compatibility issues or things like that (or to add CPU support) In the rare event of a power failure during bios update your motherboard could become permanently unusable. (Always use a brand new floppy and follow the instructions to the letter when updating system bios)
Nov 22, 2008 | ASUS P4S800D-X Motherboard
How to ID CPU compatibility?
You should try to find the manual of your mobo. Search the manufagurer website for the same model number. It usually lists all compatible CPUs.
Socket 478 is for Intel Pentium 4, Intel Celeron, Celeron D and Pentium 4 Extreme. But that doesn't mean your motherboard supports them all. You should still check the manual.
Oct 28, 2008 | Computers & Internet
No External Speaker Sound
Hi jdnimrod,
This is not you're first post about the Foxconn mother board.
You have an issue with the PS2 keyboard as well. This Foxconn model ( 761GXK8 you listed ), is not 100% correct.
Please check this link:
http://www.foxconnchannel.com/EN-US/searcher.aspx?key=761GXK8
Find which is you're board.
Than post back into this answer.
It is important you run the exact CPU that is compatible with the mother board.
Foxconn's Compatibility chart for MB to CPU.
761GXK8MB-ERS/EKRS
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606271133082354761GXK8MB.htm
761GXK8MC-RS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200603210922432734761GXK8MC-RS.htm
761GXK8MB-KRS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606300744394666200606271143263290761GXK8MB[1].htm
I'll help you further once I know the correct mother board.
Mike
Aug 08, 2008 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
Have a nice day.
Enjoy!
M
Jun 06, 2008 | ASUS P5VD2-MX SE Motherboard
Re:No POST.
http://www.intel.com/support/motherboards/desktop/d915pdt/sb/cs-026985.htm
This is Intel's website for this motherboard, which lists which CPUs are compatible.
Feb 02, 2008 | Intel Pentium 4 541, 3.2 GHz...
ASUS P5SD2-X Motherboard Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
