Question about Dometic Corp Dometic Microwave 1.2 Cu. Ft. - Silver
My Dometic Microwave oven roars very loudly during cooking and I am wondering if it is about to blow up ?
Sounds like the gears have started to grind and meshing and need lubricating!
  • 21 Answers
I would suggest taking the cover off and blowing the inside out then look for any worn gears or any that need to be lubricated,as a starting point, then go from their.
Posted on Oct 30, 2012
My Whirlpool microwave over-the-range oven makes a loud roaring sound when it turns on and won't heat.
Sounds like it could be a bad magnetron. The roaring could be a shorted mag or possibly a mag arcing in the wave guide If it is arcing in the wave guide, better to replace the unit.
Nov 01, 2017 | Microwave Ovens
Microwave occasional loud buzz
make this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Made a grr noise then shut off will not turn back on
follow this test and fix it. God bless you
Nov 06, 2013 | Emerson MWG9111SL Microwave Oven With...
Sharp microwave makes roaring noise light go on and off when i popped popcorn in bag help
Is it a loud growling noise and it doesn't cook? If so, it's probably a shorted high voltage diode. Secondly, it may be the magnetron. I don't think the popcorn had anything to do with this failure.
Oct 18, 2013 | Microwave Ovens
Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
see this causes and fix it. God bless you
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Oct 15, 2012 | Microwave Ovens
Microwave makes a loud roaring sound when start is pressed to cook something. The turntable turns and lights go on, but sound is horendous. We quickly stop it fearing it might be melting down.
Most likely it is the magnatron has gone bad, this or the fan for the magnatron. If your handy you can dissasemble the unit and look for a damaged fan, if none found then the magnatron is most likely bad.
May 07, 2011 | Sharp R-308J Microwave Oven
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
Whirlpool Talent Microwave The microwave starts off ok, then during cooking its still turning & the light is on but its not cooking. It can go on like this for 8 or 9 minutes and then you hear a small...
That is the magnetron faulty. The oven stops cooking, as the magnetron lose contact, when the magnetron restart working you hear that loud bang, and it restart radiating.
Replace the magnetron.
You find parts here or here.
Oct 08, 2008 | Whirlpool Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Dometic Corp Dometic Microwave 1.2 Cu. Ft. - Silver Logo
125 people viewed this question
Top Dometic Corp Microwave Ovens Experts
William Miller
William Miller
Are you a Dometic Corp Microwave Oven Expert? Answer questions, earn points and help others
