Question about Coleman Powermate Premium Plus 6250W Portable Generator
Generator only runs in choke position
I have Coleman-Powermate 6250 watt generator that I have had for 3 years and have not used only to let it run every 3 months or so. When I start it by choking then move the switch to run in shuts down, but will continue to run in the choke position. Could it be the gas or some other problem? I only use it during hurricane season, so it has only run for an hour or so. Thanks in advance
    Problem Solver:
  • 14 Answers
Leak at carburator gasket
Posted on Jan 03, 2009
2 Suggested Answers
  • 52 Answers
SOURCE: Coleman Powermate 6250 generator only runs with Choke on? pull
Cbronson
how old was the fuel in the tank and carb bowl? This could have built up varnish and make the float heavier
Another issue that my customers bring in are 4 stroke generators that have 2 stroke fuel put in tank.
Posted on Jan 14, 2009
I cannot locate the owners manual for my Coleman PowerMate 6250 generator 10 hp? Any place I can find this online quickly thank you
Most PowerMate manuals are available here: http://www.powermate.com/productmanuals.php?cat_id=3 . However, describing it as the PowerMate 6250 10 HP generator is insufficient to find the correct manual. The Coleman PowerMate line has several models with 10 HP engines and a 6250 Starting Watt (5000 W running) capacity.
These include the Powermate PM0435005; the direct link for this manual is http://www.powermate.com/pdfs/2011/12/29/pm0435005.02.pdf .
Please add a comment with the actual model number of your generator if you need further assistance with finding the correct manual for your generator.
I hope this helps.
Sep 05, 2017 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Jul 14, 2009 | Coleman Powermate Powermate 5000W...
I have a 3 year old Coleman Powermate 6250
Try this! To excite it. Shut off the generator! Unplug everything,Then use the 12 volt battery to excite it per manual. Make sure the engine is NOT running and the breaker switch is in the on position. Now with the battery 12V removed restart the generator! This should fix it if the problem is that it lost its magnetism.
Jun 08, 2009 | Coleman Powermate Premium Plus 6250W...
Cbronson
Jan 14, 2009 | Coleman Powermate Premium Plus 6250W...
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,288 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
