Question about Myers Pump QP7
Will the QP7 pump,pump water from a river with a 25 to 30 foot raise over a 135 foot run to provide flushing water to My cabin
  • 7,482 Answers
Hi Stephen
This is on the outer limits of what you need.
It will do it but at a low pressure
Check out the chart on the following webpage and you can see the pressure/lift scale of this pump.
Please rate me
Bud
http://www.lawnh2o.com/myers/myers_centrifugal.htm
Posted on Nov 02, 2012
1996 nissan altima no cabin heat, new radiator, flushed and filled, top hose hot, lower hose cold, newer thermostat checked good
HI Anon.
Remove your radiator cap (WHEN ENGINE IS COLD), run the motor and let it warm up a minute or two, have someone rev the engine a little while looking into the radiator. If the water goes down and/or you see the water moving, your water pump is good. If not this means that your water pump is bad and is not moving enough water through the system. Try Removing your thermostat and run the engine without it. Keep checking the radiator hoses to see if they are the same temperature. If they are not the same temperature the water pump is bad. If they are the same temperature your thermostat is more than likely the culprit. Hope this helps.
May 30, 2017 | Nissan Cars & Trucks
Cannot find the water pump to winterize 2010 Forest River Sierra. I can hear it running but am unable to locate it. The bypass valves are in the correct winterize position but the antifreeze will not go in...
You don't need to find the water pump. Make sure your water tank is empty before adding RV winterizer to the water tank. Run each faucet in the RV with bypass valve NOT in winterize position until you see the antifreeze begin to come out of the faucet. Do this for both cold and hot water side for each faucet. Then move bypass valve to winterize position and run for a few seconds.
Oct 29, 2013 | Forest River 2009 Sierra 355QBQ
How to back flush 96 Grand Am coolant system?
Hi Eric, Before you back flush have the pressure radiator cap inspected together with the cooling fan operation. A defect there will result in over heating. To back flush, detach the cabin heater pipes and open the radiator return pipe and adjust the cabin climate control to fully hot. Attach a hose pipe so that water runs opposite to the normal circulation and turn on the flow. Afterwards when refilling remember to open the air bleeder, replace coolant and run water into the system until all air is expelled from the system. Close up and test run. Keep in mind that air in the cooling system will also cause overheating. Regards John
Jul 21, 2013 | 1996 Pontiac Grand Am
2001 Blazer Replaced heater core now water pump is squealing and seems like low circulation
my 98 Blazer I had to replace radiator water pump heatercore and hoses. Had head gasket go. Once that happens air and dexcool corrode cooling system. Do you smell antifreeze? Are you loosing antifreeze? Check oil see if its another color not clear or black but i think light brown. Have you flushed out system?
Jan 31, 2013 | 2001 Chevrolet Blazer
Mastercraft 6.5 Gal.3/4 hp does not hold pressure
no it is not normal
if it is like a round tank and you use air pressure to set the operation then to have water there indicates that the diaphragm that separates the water and air has failed
nothing to with the foot valve but a non return valve at that tank or lack or set pressure
Apr 09, 2017 | Air Tools & Compressors
Our toilet Kohler 4634AA will not flush. Changed the flapper, followed the directions, etc. but still won't.flush properly...runs runs runs.
If the tank is filling with water to the line level, and the flapper raises, and stays raised until tank is almost empty, when flushed then it must be a clogged line. Try a plunger (toilet snake) and/or call a plumber.
Sep 04, 2011 | Home
95 ford conversion van with a 351 engine. replaced the radiator, water pump and thermostat last year. The water pump leaked when cold and finally replaced water pump and thermostat again. Got the leak...
If you didn't do a thorough cooling system flush with the radiator replacement last year, then i would say you may have excessive build up of rust, scale and other debris. This will certainly clog up a new radiator quickly. You may still have a restriction. I would do a good flushing, including REVERSE flushing until water runs clear. This should help... Good luck, my friend.
Feb 02, 2011 | 1995 Ford Econoline
Grundfos pump leaking?
If it is starting and stopping, it most likely does have some type of leak. The check vavlve is normally installed on the suction side of the pump, and sometimes instead of a check vavlve or in addition to, there is a foot valve. A foot valve is just a check valve (usually with a screen) at the end of the line in the bottom of the cistern. If you have much suction lift, and the check valve leaks (or any leak in the suction piping) then the water will drop back into the cistern. This will also cause the discharge side of the pump system to drop in pressure, causing the pump to restart. You mentioned removeing the pressure tank, that tank keeps the pump from short cycling when you have low demand on the system. If the pump is higher than the cistern, and you don't see a check valve between cistern and pump then you most likely have a foot vavle in the cistern. Hopefully it's accessable by removing the pipe.
Aug 01, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
As more water is pumped put of the ground, what will happen to the water table? how will this affect the wells?
We lived and raised our children in South Dakota. When the big farms started irrigating our 30 foot bored well water level dropped. When we brought this up we were told to dig a deeper well. We could not afford it. 300 foot wells were expensive. We learned how to recycle bath and laundry water. We got our kids raised up.
Feb 02, 2010 | Educational Insights Hows and Whys Of...
How do you convert a 1997 760 Yamaha Waverunner from fresh water to salt water
There is nothing to convert. After running it in salt water, you need to flush the engine out either on a garden hose or by running it in a fresh water lake or river prior to storing. Salt water is very corrosive and you need to flush your engine just as soon as possible after removing it from salt water. DO NOT let it sit overnight, it will start corroding internally and doing damage.
Aug 24, 2009 | Hayward Sand Filter System & Tank 21" 1...
Myers Pump QP7 Logo
79 people viewed this question
Top Myers Plumbing Experts
kli99gunrunn
bobalix
Gil Shultz
Are you a Myers Plumbing Expert? Answer questions, earn points and help others
