Mitusbishi WT 42385 HDTV. Having a problem getting the HDTV to work. I do not have the remote, but when you set it to HDTV channels it only shows snow in the picture. The sound works fine. Can I do something with the menu controls on the front of the TV to get it to work?
After the work we did with your rep to resolve the issue we determined that we did not have a means to fix the problem. Your rep suggested to call the cable provider and have them run a test signal. They said that would probably fix the problem, but if it didn't they may need to change the cable box. I contacted the cable company and they ran the test signal which did not work so yesterday the cable company sent a technician out and they changed the box. This corrected the problem and the HDTV is working great. Thanks for the help even though it did not work by your solution directly, you did lead me to resolve the problem.
thanks
Jeff Knight
Posted on Jan 07, 2009
How do I get hd channels to show on sceptre 32 inch classic hdtv?
Silly question, but are you subscribed to the HD channels? Most cable companies include HD channels o higher tier subscriptions, and then require a different decoder box to get them.
Aug 06, 2014 | Sceptre X322BV HD 32 inch Class Television...
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Screen cut off on the bottom - WT-42313 Mits 42"
Make sure your remote is the official Mit remote, and that it is set for TV, usually the far left setting at the top of the remote.
These remotes control many different devices. Some will allow video to work without allowing audio to work.
TV will allow all to work.
Mr Bob
Jan 23, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Can't get any channels on the air.\
If the tuner is the problem then it is a very bad problem as the tuner is part of the DM module and that is very expensive. When you say you have to manually key in the channels, do they work then? If so the problem is not the tuner. If your only problem is that you cannot go from one channel to the other by using the channel up and down button on the remote, then you have most likely just lost the programming on the tv. Go into menu and set up and find the auto channel programming and run auto program to correct the problem.
Apr 28, 2007 | RCA HD50LPW42 50" Rear Projection HDTV
WT-42413 continues to shut down. Need to wait 15 minutes to restart
End of year Followup: 2004 TV I swapped for is still working great. No issues of any sort.
Happy New Year,
Don
Jan 01, 2007 | Mitsubishi WT-42315 42" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
