Convergence on a 61
Hi i changed my convergence chips the stk392-110 to the stk392-180 and it didnt make a diffence when i tried to manual aling after about a couple of minutes the screen went black and a flashing red light started on the front of the tv. tried turning it on and off and unplugging it but does nothing but has a flashing red light when you turn it on. any suggestions thanks matt.
  • 2 more comments
  • hauffs Jan 03, 2009
    it is a hitachi 61udx10b v1loo7097, december 2001
  • hauffs Jan 04, 2009
    no i had to order the resistors no body in town has 1 watt resistors.
    ill try them thanks
  • ladywinn
    ladywinn May 11, 2010
    What is your Brand name model- chassis# year of TV will be on back of TV.
  • 5,138 Answers
Have you replaced any of the resistors? RK42 3.3ohms /RK46 1.8 RK50 2.7 / RK54 1.5 / RK58 3.9 / RK62 2.2 ,ALSO remove front cover on TV looking at front of chassis is a button on board that has ICs/ press and hold for 3 secs with TV on ,then up should be convergence Pattern for alinement.
Posted on Jan 04, 2009
How to change chips rca
I think youre refereing to convergence Issues?? If so your model doesnt have IC chips like most other brands. If your model has a convergence issue its fairy easy to fix. let me know if the issue is convergence or not and I will assist you with the issue.
Oct 24, 2011 | RCA R61WH76 61" HDTV
Sony projection tv convergance trouble. changed convergance chips, checked 8 pica fuses, checked 30 resistors all good
Replacing the IC's and the checks you did usually solves the problem.
Double check your wires - especially the R,G and B convergence wires going to the CRT necks - I've had them mislabbeled from the factory b4 and that really throws you off.
Was there any change in symptoms once the IC's were changed and do you have the negative and + supplies feeding the IC's (usually around 30VDC)
If you have the manual, have you tried service menu convergence adjustments?
Oct 24, 2009 | Sony KP-61HS10 61" Rear Projection...
Convergence
I'm assume you are referring to a non adjustable convergence option. this will occur when you have a damaged convergence chip set that is located on either the PC board or the convergence board. The location of the affected chip will vary from model to model but, in most units, this can be fixed by replacing the convergence board or chip.
May 31, 2009 | RCA HD61W66 61" Projection HDTV
I have a 61" tely that has a really bright screen. on one side of the character there is a red outline that i have trouble shot and still persists to be there.
You might consider changing the convergence chips. They do more than just adjust convergence in your set and they're pretty inexpensive.
May 23, 2009 | Philips 60PP9352 60" Rear Projection...
Sreen pulled in on top and bottom
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Sony KP-61HS10 61" Rear Projection...
KP-57HW40 Sony ..picture is blurry and gives me a headache also has a blue green tint and redish outline of the people???
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 06, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61V90 61 in. Rear... Problem
  • Screen looks 3D
Jun 18, 2008 | Sony KP-61V90 61" Rear Projection...
Convergence Problem - PT-61HX41
Your TV most likely has one or more possible problems.
  • Screen looks 3D
Jan 11, 2008 | Panasonic PT-61HX41 61" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
